Hello,
I'm just starting to use ros_control with Gazebo. I adapted the Gazebo/ROS_Control tutorial (with the RRBot) to a 6-dof robot I'm working with. Although the tutorial demo works fine, when I use a JointPositionController with a simplified, 1-dof version of the robot, I get the following output from the controller state:
header:
seq: 1097
stamp:
secs: 18
nsecs: 139000000
frame_id: ''
set_point: 2.68690323324e-08
process_value: 1.80636445357e-07
process_value_dot: 4.76481957492e-08
error: 6.28318515341
time_step: 0.001
command: 0.0
p: 0.0
i: 0.0
d: 0.0
i_clamp: 0.0
The gains are voluntarily set to zero to see what's going on without the controller being active. Note the error
that says 6.2831
although both set_point
and process_value
are essentially zero. Shouldn't the error be zero as well or am I missing something? I'm using ROS Hydro and Gazebo 1.9.5
Originally posted by JML on ROS Answers with karma: 26 on 2014-05-28
