Hi.
I am working on ROS Indigo on Ubuntu 14.04 LTE Thrusty (OK, I know it is not yet released).
When I try to start Gazebo, it fails most of the time (1 time in 10, it works). I use the simple command:
$ roslaunch gazebo_ros empty_world.launch
Here are the messages:
... logging to /home/arnaud/.ros/log/251a3d96-e35b-11e3-9539-0016eae586be/roslaunch-hercules-11967.log
Press Ctrl-C to interrupt
started roslaunch server http://hercules:46195/
SUMMARY
PARAMETERS
 * /rosdistro: <...>
 * /rosversion: <...>
 * /use_sim_time: True
NODES
    gazebo (gazebo_ros/gzserver)
    gazebo_gui (gazebo_ros/gzclient)
auto-starting new master
process[master]: started with pid [11979]
setting /run_id to 251a3d96-e35b-11e3-9539-0016eae586be
process[rosout-1]: started with pid [11992]
started core service [/rosout]
process[gazebo-2]: started with pid [12016]
/opt/ros/indigo/lib/gazebo_ros/gzserver: 5: [: Linux: unexpected operator
process[gazebo_gui-3]: started with pid [12020]
/opt/ros/indigo/lib/gazebo_ros/gzclient: 5: [: Linux: unexpected operator
Gazebo multi-robot simulator, version 2.2.2
Copyright (C) 2012-2014 Open Source Robotics Foundation.
Released under the Apache 2 License.
http://gazebosim.org
Msg Waiting for masterError [Connection.cc:787] Getting remote endpoint failed
terminate called after throwing an instance of 'boost::exception_detail::clone_impl<boost::exception_detail::error_info_injector<boost::system::system_error> >'
  what():  remote_endpoint: Transport endpoint is not connected
[ INFO] [1400946636.551182005]: Finished loading Gazebo ROS API Plugin.
[ INFO] [1400946636.557603492]: waitForService: Service [/gazebo/set_physics_properties] has not been advertised, waiting...
Msg Connected to gazebo master @ http://127.0.0.1:11345
Msg Publicized address: 192.168.1.211
Aborted (core dumped)
[gazebo_gui-3] process has died [pid 12020, exit code 134, cmd /opt/ros/indigo/lib/gazebo_ros/gzclient __name:=gazebo_gui __log:=/home/arnaud/.ros/log/251a3d96-e35b-11e3-9539-0016eae586be/gazebo_gui-3.log].
log file: /home/arnaud/.ros/log/251a3d96-e35b-11e3-9539-0016eae586be/gazebo_gui-3*.log
[ INFO] [1400946637.091142150, 0.022000000]: waitForService: Service [/gazebo/set_physics_properties] is now available.
[ INFO] [1400946637.167613885, 0.093000000]: Physics dynamic reconfigure ready.
^C[gazebo-2] killing on exit
[rosout-1] killing on exit
[master] killing on exit
shutting down processing monitor...
... shutting down processing monitor complete
done
This one fails either:
roscore & rosrun gazebo_ros gazebo
The only way I found to make it work is to start one by one, roscore, gzserver and gzclient.
Does it come from the unstable state of ROS Indigo? Any idea how to fix this?
Thanks.
Originally posted by Arn-O on ROS Answers with karma: 107 on 2014-05-24
Comment by Arn-O on 2014-05-26:
Any ideas are welcome. Do you think that it could come from my hardware? (LENOVO T400)
Comment by Arn-O on 2014-05-27:
I have found the same issue on the Gazebo forum: http://answers.gazebosim.org/question/6271/getting-remote-endpoint-failed-let-gazebo-gui/
Comment by Arn-O on 2014-05-28:
Finally posted an issue in GitHub: https://github.com/ros/ros_comm/issues/421
Comment by Orso on 2014-09-11:
I experience same issue, running ROS Hydro, Ubuntu 12.04. roscore & rosrun gazebo_ros gazebo does not work, produces the following error: terminate called after throwing an instance of 'std::bad_alloc' what(): std::bad_alloc Yet, I am able to start gazebo using roscore, gzserver, and gzclient.
This was resolved here: https://github.com/ros-simulation/gazebo_ros_pkgs/issues/196
Originally posted by tfoote with karma: 58457 on 2017-10-16
