Using this code
geometry_msgs::PoseStamped current_position()
        tf::TransformListener my_temp_listener;
        geometry_msgs::PoseStamped  pose;
        pose.header.stamp = ros::Time::now();
        pose.header.frame_id = "/base_link";
        pose.pose = pose_zero;
        my_temp_listener.waitForTransform("map", "/base_link", ros::Time(0), ros::Duration(3.0));
        tf::StampedTransform my_transform;
        my_temp_listener.lookupTransform("/map","/base_link",ros::Time(0), my_transform);
        my_temp_listener.transformPose("map", pose, pose);
        return pose;
I get terminate called after throwing an instance of tf::ExtrapolationException
  what():  Unable to lookup transform, cache is empty, when looking up transform from frame [/base_link] to frame [/map] at runtime.
However, looking at the frames using rosrun tf tf_echo /base_link /map I correctly get
At time 1400687504.239
  • Translation: [-8.817, 0.695, 0.000]
  • Rotation: - in Quaternion [0.000, 0.000, 0.097, 0.995] - in RPY [0.000, -0.000, 0.194]
    Thank you!
Originally posted by Rahndall on ROS Answers with karma: 133 on 2014-05-21
You need to give the listener time to build up it's cache of data. I suggest that you go through the tf tutorials which cover these sorts of issues.
Originally posted by tfoote with karma: 58457 on 2014-05-21
Thank for the suggestion
I solved in this way and it works, I don't know if it is the best solution
        ros::Time now = ros::Time::now();
        pose.header.stamp = now;
        try {
                mRosTransformListener->waitForTransform("/base_link", "/map", (now+ros::Duration(1.0)), ros::Duration(10.0) );
                mRosTransformListener->lookupTransform("/base_link", "/map", now, my_transform);
        catch (tf::TransformException ex) { ROS_ERROR("%s",ex.what()); }
        if (mRosTransformListener->frameExists("/map"))
                ROS_INFO ("/map exist");
        if (mRosTransformListener->frameExists("/base_link"))
                ROS_INFO ("/base_link exist");
        try {
                mRosTransformListener->transformPose("/map", pose, pose);
        ROS_INFO("pose %f %f %f", pose.pose.position.x, pose.pose.position.y, pose.pose.position.z);
        return pose;
Thank you again for you support
Originally posted by Rahndall with karma: 133 on 2014-05-22
