When i type the apt-get install command, i get ,
sudo apt-get install ros-hydro-desktop-full Reading package lists... Done Building dependency tree
Reading state information... Done Some packages could not be installed. This may mean that you have requested an impossible situation or if you are using the unstable distribution that some required packages have not yet been created or been moved out of Incoming. The following information may help to resolve the situation:
The following packages have unmet dependencies: ros-hydro-desktop-full : Depends: ros-hydro-desktop but it is not going to be installed Depends: ros-hydro-perception but it is not going to be installed Depends: ros-hydro-simulators but it is not going to be installed E: Unable to correct problems, you have held broken packages.
Originally posted by amartya18x on ROS Answers with karma: 1 on 2014-05-21
Do you have the universe and metaverse repositories enabled?
Originally posted by ahendrix with karma: 47576 on 2014-05-21
