Hi, I am importing a 6 DOF arm using setupAssistant. When I load the urdf for the robotic arm, all the parts of the robotic arm are at the same plane. It shows a message "No root joint specified. Assuming fixed joint".
I searched in other threads and came across that there is some information to be added in the SRDF file. Since I have generated the URDF from Solidworks, so please tell where should I create a SRDF for the same and whether we have to load the URDF or the SRDF of the robot to fix this.
Here are the console logs:
[ INFO] [1400146129.617803918]: Loaded robot robot model.
[ INFO] [1400146129.618207340]: Setting Param Server with Robot Description
[ INFO] [1400146129.632349428]: Robot semantic model successfully loaded.
[ INFO] [1400146129.632505515]: Setting Param Server with Robot Semantic Description
[ INFO] [1400146129.664284638]: Loading robot model 'robot'...
[ INFO] [1400146129.664376122]: No root joint specified. Assuming fixed joint
[ INFO] [1400146130.118231108]: Stereo is NOT SUPPORTED
[ INFO] [1400146130.118454828]: OpenGl version: 3 (GLSL 1.3).
[ INFO] [1400146130.830133313]: Loading robot model 'robot'...
[ INFO] [1400146130.830429200]: No root joint specified. Assuming fixed joint
[ INFO] [1400146131.398639691]: Loading robot model 'robot'...
[ INFO] [1400146131.398745909]: No root joint specified. Assuming fixed joint
[ INFO] [1400146131.688112326]: Loading Setup Assistant Complete
Originally posted by rvijay on ROS Answers with karma: 41 on 2014-05-14
Comment by clark_txh on 2016-09-30:
hello I get the same proplem, can you tell me ,how sovle it.
Strange as it may sound, when running in debug mode using gdb worked around the issue for a person I was helping.
$ roslaunch moveit_setup_assistant setup_assistant.launch debug:=true
Originally posted by 130s with karma: 10937 on 2015-04-23
Comment by gvdhoorn on 2015-04-24:
You did not get the message No root joint .. when running the Setup Assistant in gdb?
Comment by 130s on 2015-04-24:
Not that I know of (this was happening on someone else' computer I was helping).
That sounds rather strange: the message essentially tells you that there is no joint connecting base_link to the 'world' (however that is defined). Running in gdb or not should not affect this.
