I want to save these topics in file :/amcl/parameter_descriptions /amcl/parameter_updates
what can i do?
Originally posted by yasamin on ROS Answers with karma: 11 on 2014-05-14
rosbag is the thing you are looking for.
http://wiki.ros.org/rosbag
Good described in this tutorial.
Originally posted by BennyRe with karma: 2949 on 2014-05-14
Comment by yasamin on 2014-05-14:
Thank you I have a problem with these :rosbag record -a when i type these command give me these error :[ WARN] [1400075193.299487382]: /use_sim_time set to true and no clock published. Still waiting for valid time...
what can i do??
Comment by ahendrix on 2014-05-14:
It sounds like you have (or had) a simulator running, but for some reason it isn't publishing the clock topic, or your rosbag node can't subscribe to it. You should make sure the simulator is running, and see if there are any messages published to /clock
