Hi, I am running four computers with only one the ROS master, and I am sure I set the correct ROS_MASTER_URI (=http://192.168.10.101:11311) to the other three computers. Then the problems like this: I run a node in the master computer, and also I publish some message to that node. In this master computer, I can use "rostopic echo" to see the published messages, but in another computer, if I run "rostopic list", I see all the topics, but if I run "rostopic echo /xxxx" then I cannot see anything. Most importantly, I see the master computer threw out a message saying Couldn't find an AF_INET address for [msl]. It is probably some network problem, so please help.
Originally posted by skyhawk on ROS Answers with karma: 201 on 2014-05-10
Post score: 13
7 Answers 7
skyhawk is right, set the ROS_IP for each computer. So for each computer, find the IP address in a terminal with
hostname -I
It will be the first set of numbers, like 10.0.0.25. To set it,
export ROS_IP=10.0.0.25
Make sure you're exporting the right address on each one, it'll be different for each computer.
Originally posted by mattc12345 with karma: 328 on 2014-07-30
Post score: 30
Comment by fabbro on 2019-10-08:
This worked for me! Thanks
Comment by blubbi321 on 2020-05-22:
(as mentioned in posts below): In case this does not solve your problem edit /etc/hosts to contain the name for the rosnode. For example in there add 192.168.3.5 my_hostname
You should set the ROS_IP for each computer that is in the network running the ROS.
Originally posted by skyhawk with karma: 201 on 2014-05-10
Post score: 7
Or just set on every computer in you network (so you don't have to thing about addresses):
export ROS_IP=`hostname -I`
Or even, sometimes better, solution is to add this line in your .bashrc file.
Post score: 5
Comment by ahendrix on 2014-09-04:
Be warned - this only works if your computer only has one IP address. If you have two addresses, perhaps ethernet and WiFi, hostname -I will show multiple addresses and your ROS_IP will probably be invalid.
Comment by cellard0or on 2016-08-03:
@ahendrix In the case of multiple addresses, what address do have to set ROS_IP to? I set it to the one which used for communication between host and the ROS PC but it did not work.
Comment by ahendrix on 2016-08-03:
@cellard0or : that approach should work, but you've given very little information. Please ask a new question with details about your setup and the errors you're encountering.
Comment by blubbi321 on 2017-11-01:
as current ubuntu revisions seem to report more than just the ip when calling hostname -I I used
machine_ip=(`hostname -I`)
export ROS_IP=${machine_ip[0]}
The only solution that worked for me was to list the ip address of each computer along with its hostname to the /etc/hosts file.
Post score: 6
Comment by pulver on 2015-06-08:
Thank you! In my case, having two ip address on the robot and two on the workstation, this was the only one working solution!
I also already had the suggested #1 solution implemented and this helped to get rid of the error
If this is coming from a gazebo plugin -- it may be because gazebo is beignn run standalone rather than launched from ros as required.
I would say the best answer... worked 100% for my robot and local computers. have a look... http://www.umiacs.umd.edu/~cteo/umd-erratic-ros-data/README-rvis-remote
I found a way, change your /etc/hosts Such as:
vim /etc/hosts
then add your ip:
Comment by kotoko on 2018-08-06:
This was the only thing that worked for me after adding ROS_IP
