After running 3dsensor.launch on the turtlebot, I am trying to subscribe to the kinect topics, but am running into trouble. Although I can subscribe to topics like /scan and /camera/depth_registered/image_raw, they don't give me any values, like they should. /scan publishes the correct header type data, but then large arrays of what should be accurate data but are just Nan Nan Nan over and over. camera/depth_registered/image_raw publishes a bunch of 0's in place of data. camera/rgb/image color publishes properly, but /camera/depth/points publishes no messages. It seems there is a problem with publishing the topics that involve depth data, but i'm not sure why.
Note: I recently had a problem with the kinect wherin the turtlebot would tell me that "no devices were connected" when I ran 3d sensor.launch, even though the kinect was clearly plugged in. I solved this problem by removing everything on the turtlebot that had to do with the open_ni sensor kinect drivers, and then reinstalling them from online. Reading online about my current problem, I see that a common suggested fix is to do basically this, so I'm a little confused as to why reinstalling open_ni solved only the first but not the second problem (if that really is the fix).
Another note: the depth data is published correctly if I run the follower turtlebot follower tutorial instead of running 3dsensor.launch directly.
Originally posted by mysteriousmonkey29 on ROS Answers with karma: 170 on 2014-05-10
Comment by Sudeep on 2014-05-11:
Hi Lewis, I am having similar trouble with my device, Even it's plugged in, system gives an error "no devices were connected". How did you remove this issue? Can you please share the link here? Thank You, Sudeep
Comment by mysteriousmonkey29 on 2014-05-14:
In order to solve the problem you're having, I did apt-get remove OPEN_NI*, and then we reinstalled OPEN_NI from the repository online. And then I had to reboot and stuff but it worked
Comment by Sudeep on 2014-05-14:
Thank you very much I will try that :)
There is a conflict with having both the depthclound and registered depthcloud launching at the same time. To view the depthcloud, set the registered depthcloud arguments to false when launching 3dsensors.launch
roslaunch turtlebot_bringup 3dsensor.launch depth_registered_processing:=false depth_registration:=false
You can then launch view_robot.launch as you normally would.
Originally posted by MartinCote with karma: 76 on 2014-10-24
