Hi I am currenting trying the autonomous navigation tutorial for turtlebot. I am having issue having it move to my goal location. While observing rviz, the turtlebot seems to have issue localizing itself properly. Even when the robot its at rest, rivz show that the turtlebot's orientation is slowly turning. Anyone have any ideas what might be causing this ?
Thanks
Originally posted by zenifed on ROS Answers with karma: 93 on 2014-05-04
Comment by jihoonl on 2014-05-06:
Are you using create or kobuki?
Comment by zenifed on 2014-05-06:
i am using kobuki.
Does odom topic drift?
I am not sure.The drifting issue seem to have disappeared though after loading another map though.
Kobuki gyro is factory calibrated, so no need to re-calibrate again. The problem you report is a particularity of the installed gyro that hapen rarely. It's fixed on firmware version 1.1.4, so check your robot firmware version
rostopic echo /mobile_base/version_info
And update it if it's older. Here's the how to.
Originally posted by jorge with karma: 2284 on 2014-06-02
Comment by dornhege on 2014-06-11:
We observed the same problem. As a quick fix: Shutting down the drivers and turning the robot off and on solved that. (So, yes, we tried turning it off and on again!)
Comment by jorge on 2014-06-11:
Clearly is the gyro. Update the firmware will solve it so you don't need to switch off/on nevermore.
Thanks, we'll do that. I can confirm that it was the gyro. We've seen it directly in the diagnostics.
Comment by zenifed on 2014-06-15:
hi sorry for the late response. That seems to be the source of the problem, have updated the robot. Thanks
