Hi,
I have uninstalled ROS hydro, and tried to install it again but the setup.bash file is missing (i.e. not created). How can i fix that problem?
Thnx
Originally posted by abd_el_mon3em on ROS Answers with karma: 1 on 2014-05-03
Comment by Bastbeat on 2014-05-03:
Is missing, in a new workspace or in /opt/ros/hydro?
Comment by prince on 2014-05-04:
Check your catkin workspace for this file.
If you are referring to the /opt/ros/hydro/setup.bash file being missing then you might have only some ROS hydro pakcages installed but not some of the low level packages. Try to install the ROS base packages:
sudo apt-get install ros-hydro-ros-base
Originally posted by Dirk Thomas with karma: 16276 on 2014-05-04
