Hi,
I have a problem when I build my package with catkin_make This is my code:
#include <ros/ros.h>
#include <moveit/move_group_interface/move_group.h>
  ros::init(argc, argv, "mov_1");
  ros::AsyncSpinner spinner(1);
  spinner.start();
  move_group_interface::MoveGroup group("manipulator");
  group.setRandomTarget();
  group.move();
CMakeList.txt:
project(prueba_movimiento)
  moveit_core
  roscpp
catkin_package(
  INCLUDE_DIRS include
  LIBRARIES prueba_movimiento
  CATKIN_DEPENDS moveit_core roscpp
  DEPENDS system_lib
include_directories(
  ${catkin_INCLUDE_DIRS}
add_executable(mov_1 src/mov_1.cpp)
target_link_libraries(mov_1
  moveit_move_group_interface
Error when I run catkin_make :
In file included from /opt/ros/hydro/include/moveit/robot_model/joint_model_group.h:41:0,
                 from /opt/ros/hydro/include/moveit/robot_model/robot_model.h:48,
                 from /opt/ros/hydro/include/moveit/robot_state/robot_state.h:41,
                 from /opt/ros/hydro/include/moveit/move_group_interface/move_group.h:40,
                 from /home/ramon/catkin_ws/src/prueba_movimiento/src/mov_1.cpp:2:
/opt/ros/hydro/include/moveit/robot_model/joint_model.h:47:26: fatal error: Eigen/Geometry: No such file or directory
How can I fix this??
Thanks.
Originally posted by rcj1986 on ROS Answers with karma: 121 on 2014-05-01
Post score: 4
Comment by Dirk Thomas on 2014-05-01:
You should post you CMake file.
Comment by rcj1986 on 2014-05-01:
CMakeList.txt:
cmake_minimum_required(VERSION 2.8.3) project(prueba_movimiento)
find_package(catkin REQUIRED COMPONENTS moveit_core roscpp )
catkin_package(
DEPENDS system_lib
include_directories( ${catkin_INCLUDE_DIRS} )
target_link_libraries(mov_1 moveit_move_group_interface )
Comment by Dirk Thomas on 2014-05-02:
Please edit your question and add your CMake there. In the comment the code is not really readable.
Please also add the exact error message you are getting.
Can you please add the following message to your CMake and post the result: message("moveit_core_INCLUDE_DIRS ${moveit_core_INCLUDE_DIRS}")
3 Answers 3
Try adding these lines to your CMakeLists.txt:
find_package(Eigen REQUIRED)
include_directories(SYSTEM ${Boost_INCLUDE_DIR} ${EIGEN_INCLUDE_DIRS})
I did this after I saw the moveit pr2 tutorials by Sachin Chitta.
Originally posted by McMurdo with karma: 1247 on 2014-07-24
Linking CXX executable /home/ramon/catkin_ws/devel/lib/prueba_movimiento/mov_1
/usr/bin/ld: cannot find -lmoveit_move_group_interface
collect2: ld returned 1 exit status
make[2]: *** [/home/ramon/catkin_ws/devel/lib/prueba_movimiento/mov_1] Error 1
make[1]: *** [prueba_movimiento/CMakeFiles/mov_1.dir/all] Error 2
make: *** [all] Error 2
Invoking "make" failed
Originally posted by rcj1986 with karma: 121 on 2014-05-02
Comment by isura on 2014-05-09:
@rcj1986 please edit the original question when posting updates instead of posting an answer to your own question. Unless this was the answer to your own question.
I had the same error . I solved it by adding find_package(catkin REQUIRED COMPONENTS moveit_ros_planning_interface) to my CMakeLIsts.txt file.
Post score: 9
Comment by Burak Teke on 2017-10-25:
I've tried it and it works. I added that to my CMakeLists.txt and at the same time I added "moveit_ros_planning_interface" to my package.xml file as a dependency.
