This is the package manager complaining that it can't find the dependencies for ROS for some reason.
aptitude is better at resolving these things sometimes; try running:
sudo aptitude install ros-hydro-desktop-full
But be careful to read the solutions that it proposes; sometimes they can involve removing or downgrading other packages that you have installed, which may not be what you want.
Originally posted by ahendrix with karma: 47576 on 2014-04-16
Comment by billtecteacher on 2014-04-16:
ubuntu@ubuntu:~$ sudo aptitude install ros-hydro-desktop-full
sudo: aptitude: command not found
ubuntu@ubuntu:~$ sudo apt-get aptitude
E: Invalid operation aptitude
ubuntu@ubuntu:~$
How does one get aptitude on to system?
aptitude was not able to resolve dependencies
Comment by ahendrix on 2014-04-16:
I suspect aptitude gave you different errors; can you add those to your question?
Comment by billtecteacher on 2014-04-17:
Just started today looking into debian packages. There is a lot to the package system that I always took for granted because it worked for me. There are 300 + packages not getting installed including collida and on down the list. If I put a more to see the first part of the command I get the following and it returns to prompt after this instead of sending a ton of messages to the screen:
ubuntu@ubuntu:~$ sudo aptitude install ros-hydro-desktop-full | more
E: Could not get lock /var/lib/dpkg/lock - open (11: Resource temporarily unavailable)
E: Unable to lock the administration directory (/var/lib/dpkg/), is another process using it?
Reading package lists...
Building dependency tree...
Reading state information...
Reading extended state information...
Initializing package states...
ubuntu@ubuntu:~$
The lock file in last post for some reason was left with a permission which killed the script. I can fix the lock permission and it goes back to error with list of 300+ packages not installed. I think I can learn more myself diving into aptitude command thanks to you.
Comment by ahendrix on 2014-04-17:
Yeah, there's quite a bit to the package manager. It may be worth confirming that you have the restricted
, universe
and multiverse
repositories enabled.
