Hi, I try to make a moveIt package. I follow the tutorial and finish it without problems, but when I try to launch the new package with "roslaunch new_moveit_package demo.launch"
[demo.launch] is neither a launch file in package [new_moveit_package] nor is [new_moveit_package] a launch file name
Any idea??
Originally posted by rcj1986 on ROS Answers with karma: 121 on 2014-04-11
Comment by Bastbeat on 2014-04-11:
http://answers.ros.org/question/151656/problem-with-ikfast_moveit-tutorial/
what tutorial did you do?
Comment by rcj1986 on 2014-04-11:
This http://aeswiki.datasys.swri.edu/rositraining/Exercises/3.3
http://moveit.ros.org/wiki/Kinematics/IKFast Try the part "Create plugin" of this Tutorial. if you did correctly the moveit assistante tutorial, it should work
This sounds like your newly created package is not in your ROS_PACKAGE_PATH. See these Q/As for more info on that: 1, 2, 3. You either have to put your new package into a folder that is already in your ROS_PACKAGE_PATH, or add your package folder to it.
Originally posted by Stefan Kohlbrecher with karma: 24361 on 2014-04-11
Comment by rcj1986 on 2014-04-13:
Thanks, when I save the package in my ROS_PACKAGE_PATH it works!!
