Hi everyone.
I have been trying to simulate two Turtlebot II on Gazebo.
I wonder if it is possible to perform simulations with time increased several times (pun). I'm not really concerned in visually observe the movements, but I want to run several times the same simulation and store different measurements / data for statistical analysis of the project I'm working on.
Is this kind of high-speed simulation possible in Gazebo?
Originally posted by Carlos Hdz on ROS Answers with karma: 103 on 2014-04-10
Given that gazebo always performs real-time dynamics simulation, there are limits to the speed that can be achieved on commodity hardware. There are some options though:
  • Get a faster computer
  • Reduce dynamics simulation fidelity (time step, solver iterations). Might make simulation unstable though
  • Reduce scenario/robot complexity (simple geometries, switch off/don't use sensors you don't need)
If you only require a relatively abstract robot model, using Stage or the recently introduced STDR simulator instead might be another option.
Originally posted by Stefan Kohlbrecher with karma: 24361 on 2014-04-10
Comment by Carlos Hdz on 2014-04-10:
mmm... I will try them... Thank you!
