All of the search results I find for interaction for ROS and PCL are a few years old. I'm curious if there is a way to save PCD files from Kinect streams directly by a ROS input. Let's assume that the Kinects are launched through the standard openni.launch approach with names kinect_1 and Kinect_2. Would I be able to take "snapshots" of the stream and then use that data for a PCD file and PCL applications?
Originally posted by Athoesen on ROS Answers with karma: 429 on 2014-04-07
I´m not aware of any official implementation, but writing a small node(let) that does this should be pretty easy. In this Q/A something very close to what you want to do is discussed (along with code).
Originally posted by Stefan Kohlbrecher with karma: 24361 on 2014-04-07
