Hi, I wander known how I can subscribe a known laserscan
Originally posted by flightgong on ROS Answers with karma: 3 on 2014-04-06
Hi
I am assuming you have done all the beginner tutorials, because they explain subscribers, topics and publishers really well see here http://wiki.ros.org/ROS/Tutorials/WritingPublisherSubscriber%28python%29
If you want to know the name of the laser scan topic run the laser_node or the node that publishes the laser scan use rostopic list to figure out the name of the topic. eg "chatter" in the beginner tutorials
In order to write your subscriber you need to import the msg http://docs.ros.org/api/sensor_msgs/html/msg/LaserScan.html eg
from sensor_msgs.msg import LaserScan
Once your callback function is triggered you will get back a struct that is defined by the .msg file
you can also use the rosmsg XXX command to figure out the types of msgs packages publish from the terminal and their format.
Originally posted by Sentinal_Bias with karma: 418 on 2014-04-06
Comment by flightgong on 2014-04-06:
Hi, I have found the laser_node, and its published laser topic, for example named base_scan. When I try to use this data in my subscriber, it returns that this global name doesn't exist. I don't know how to deal with it. Thx
Comment by Sentinal_Bias on 2014-04-08:
do you mean the data in your subscriber function? It should be a struct as defined by the msg file
