Based on a question asked in this link http://answers.ros.org/question/127581/rgbdslam-and-octomap/,
Mr. Felix answered, "Have rgbdslam send out the clouds+tf transformations and let the octomap_server listen." which I already did as depicted in the rxgraph attached below.
http:// s7.postimg.org/xw5l3rph7/Screenshot_from_2014_04_05_18_02_14.png
Given I had already did this, how do you visualize the Octomap? I read that the visualization tool is Octovis which I already installed but how will you render the registered point clouds to the Octovis?
Originally posted by Xegara on ROS Answers with karma: 52 on 2014-04-05
Comment by xuningy on 2014-05-28:
I am running into the same issue for not being able to map rgbdslam to octomap with /tf issues. SInce you mentioned that Mr. Felix's suggestions were implemented in your solution " "Have rgbdslam send out the clouds+tf transformations and let the octomap_server listen.", would you be able to elaborate on how you did that ( as your rxgraph is a very tiny screen shot )
The octomap server should output a view topics which you can visualize in Rviz. See the occupied_cells_vis_array topic.
http://wiki.ros.org/octomap_server?distro=hydro
Originally posted by davinci with karma: 2573 on 2014-04-05
Comment by Xegara on 2014-04-05:
So octomap can be visualized in Rviz. How about Octovis? Is not the Octovis the visualization tool of the Octomap?
Comment by davinci on 2014-04-05:
Octovis is a stand alone tool as far as I know. You have to save the OctoMap as a .bt or .ot file and load this in to Octovis.
