Since Gazebo is deprecating URDF and moving to SDF, it seems like ROS might follow suit.
Is URDF depricated, or about to be?
If so are there tools which work with SDF? For instance will robot_state_publisher be able to handle SDF defined robots?
If not, should we be sticking to using URDF for defining our robot models?
Originally posted by Asomerville on ROS Answers with karma: 2743 on 2014-04-02
Post score: 6
Comment by demmeln on 2014-04-03:
cc @nkoenig
Comment by Kurt Leucht on 2014-04-03:
I recently found that in trying to learn Gazebo, they tend to focus on SDF and not give me any examples of URDF usage in Gazebo. But in the Gazebo tutorial section about ROS integration all the examples use URDF and I get stuck because all the other tutorials teach only SDF. Very frustrating.
hm, I am not aware of such deprecation. Can you point me to the originating source of that news? Thanks.
No. The reason being URDF is still useful for things outside of simulation. SDF tools / Gazebo will continue to parse URDF formats.
If so, I am not aware of them yet.
Not that I am aware of. Though a good starting point is a feature request on an issue tracker :)
Yes. You can always use gzsdf print or gz sdf -p (gazebo 3.x) to convert URDF to SDF.
But there may be reasons to use SDF if the project is simulation specific or will not rely on existing ROS tools?
Kurt,
If you want to see more examples / tutorials in URDF, please comment/up-vote this issue: https://bitbucket.org/osrf/gazebo_models/issue/16/create-more-urdf-examples
Thanks.
Originally posted by hsu with karma: 5780 on 2014-04-03
Post score: 5
Comment by Asomerville on 2014-04-08:
I may have jumped to conclusions, but I got that impression from the idea that SDF supersedes functionality of URDF, and posts like this: http://answers.gazebosim.org/question/62/sdf-vs-urdf-what-should-one-use/
I'm curious to know why URDF isn't being deprecated, but I'll ask in a different forum.
