Hi guys, I am using ROS hydro for kinect. When I use rviz to show the point clouds (unregistered and registered), the window turns very slow. The display can response even two or three seconds. Could anyone give me some suggestions to fix this problem? Many thanks.
Originally posted by pinocchio on ROS Answers with karma: 101 on 2014-04-01
Comment by byeongkyu on 2014-04-01:
Can I know your machine specification? Graphic card performance is very important to view point cloud.
Comment by Ken_in_JAPAN on 2014-04-01:
Could you explain more detail? For example, with multi machine or with single machine? In case of multi machine, we can guess a problem on network. In case of single machine, we can guess a problem on graphic card as Mr. byeongkyu says.
Comment by demmeln on 2014-04-02:
Also, did you compile rviz from source, or did you install it with apt?
Comment by pinocchio on 2014-04-02:
@byeongkyu @Ken_in_JAPAN @demmeln Hi guys, thanks for you help. I am using single machine for rviz, and rviz is installed with hydro by default. I think it is installed with apt.
The computer's detailed information: Processor: Intel(R) Core(TM) i5 CPU U 540 @ 1.20GHz (4 CPUs), ~1.2GHz Memory: 8192MB RAM
Display: Name: Intel(R) HD Graphics Chip Type: Intel(R) HD Graphics (Core i5) DAC Type: Internal
@pinocchio: Installing from apt should be ok. If installing from source, you might get bad performance if your forget to set the CMAKE_BUILD_TYPE to Release. Not sure if this should be faster on your machine.
Comment by byeongkyu on 2014-04-02:
@pinocchio: It is recommend that upgrade your graphic card, and set your cpufreq to performance mode.
Comment by Qt_Yeung on 2014-07-21:
Have you solved this problem? My computer slows down the same when I display the point cloud in rviz.
The most likely cause is that you're not using hardware accelerated video drivers. Rviz works best with nVidia graphics cards and the propriety driver. My guess is that you're using software rendering (as opposed to taking advantage of the hardware on the GPU), and that this is what's causing the slow-down. I'd suggest that you make sure you're using hardware-accelerated video drivers, and see if that helps.
The best long-term solution, though, is probably to switch to an nVidia video card.
Originally posted by Bill Smart with karma: 1263 on 2014-07-22
