This answer gives a good overview of what the requirements are for the turtlebot1 gyro: http://answers.ros.org/question/115741/parallax-gyro-work-on-turtlebot-1/#116621
Looking at your gyro ( http://support.robotis.com/en/product/auxdevice/sensor/dxl_gyro.htm ) and doing a little math, it looks like it reads 1V/300 degrees/sec ~= 3.3 mV/degree/sec. Not quite as sensitive as the original gyro; you may have to make some adjustments.
There are also a number of other questions the discuss alternate gyros for the turtlebot:
http://answers.ros.org/question/31341/gyro-for-turtlebot/ ( http://www.pololu.com/product/1255/ )
http://answers.ros.org/question/12745/gyro-for-turtlebot/ (discusses adjusting the gyro sensitivity)
http://answers.ros.org/question/11161/gyro-substitute-for-turtlebot/?answer=16553#post-id-16553
http://answers.ros.org/question/10437/using-a-different-gyro-on-a-turtlebot/
Originally posted by ahendrix with karma: 47576 on 2014-04-01
Comment by assil on 2014-04-10:
Thank you for your answer ahendrix :) it really helps me .
Comment by assil on 2014-06-05:
Hi ahendrix,
You told me that I may have to make some adjustments to work correctly with my this sensor.
I'm confused, what kind of adjustments I shoud do.
This gyro doesn't work for me. Using it, my maps was really a mess ! :(
I need your help.
Kind regard.
