Hello everybody,
i wanted to know is there any way out by which i can 2 or more servos at a time from a single subscriber. Currently i am running one servo on a single channel of arduino Due. But i require two servos to be run at a same time by giving them different angle values. like;
rostopic pub Servo1 std_msgs/Int16 230;
this passes 230 degree to the servo attached. But i want to control two at a time like;
rostopic pub Servo1 std_msgs/Int16 230 130 240;
230 for 1st servo; (degrees) 130 for 2nd servo; (degrees) 240 for 3rd servo...(degrees)
I would appreciate if someone puts a light on this issue.
thnks
Originally posted by sonny on ROS Answers with karma: 33 on 2014-03-29
You've got two options. Most straightforward would be a basic custom message with an array. This answer may help. Second option which is more elegant and involves less code is a MultiArray.
Originally posted by Ryan with karma: 3248 on 2014-03-29
Comment by s1 on 2015-09-22:
can anyone give an example of MultiArray usage please.
here is an example using MultiArray
#if (ARDUINO >= 100)
 #include <Arduino.h>
#else
 #include <WProgram.h>
#endif
#include <Servo.h>
#include <ros.h>
#include "std_msgs/MultiArrayLayout.h"
#include "std_msgs/MultiArrayDimension.h"
#include "std_msgs/UInt16MultiArray.h"
ros::NodeHandle  nh;
Servo servo1;
Servo servo2;
void servo_cb( const std_msgs::UInt16MultiArray&  cmd_msg){
  servo1.write(cmd_msg.data[0]); //set servo angle, should be from 0-180
  servo2.write(cmd_msg.data[1]);
  digitalWrite(13, HIGH-digitalRead(13));  //toggle led
ros::Subscriber<std_msgs::UInt16MultiArray> sub("servo", servo_cb);
void setup(){
  pinMode(13, OUTPUT);
  nh.initNode();
  nh.subscribe(sub);
  servo1.attach(9); //attach it to pin 9
  servo2.attach(10);//attach it to pin10
void loop(){
  nh.spinOnce();
  delay(1);
Publisher:
 rostopic pub servo std_msgs/UInt16MultiArray '{data: [<angle1>, <angle2>]}'
Originally posted by Chuong Nguyen with karma: 136 on 2015-10-12
Comment by s1 on 2015-10-16:
thank you!!!
Comment by s1 on 2015-12-23:
is it possible to delay servo2 so that I can time the action? In other words I dont want all of the servos to fire off at once.
Comment by Frank Lee on 2017-09-05:
Maybe consider publishing the message to servo 2 separately, delay accounted for?
