Hi,
I'm using Matlab/ROS interface (with Matlab R2013a and ROS fuerte)
I've done the Matlab example where a node publish and subscriber from Matalb and this example works without problem. But now I have gazebo running and I want to subscrib from Matlab and It doesn't work.. Could anyone tell me what is wrong?
I do: roscore
roslaunch gazebo_world ....
and execute this code from Matlab:
global rosMasterIp; rosMasterIp = '127.0.1.1';
global localhostIp; localhostIp = '127.0.0.1';
% Create a new node named /NODE and connect it to the master.
node = rosmatlab.node('NODE', rosMasterIp, 11311, 'rosIP', localhostIp);
% Add a publisher of a topic named /TOPIC to the node to send message of type std_msgs/String.
publisher = rosmatlab.publisher('TOPIC','std_msgs/String',node);
% Add a subscriber to a topic named /TOPIC to the node to receive message
subscriber = rosmatlab.subscriber('TOPIC','std_msgs/String',1,node)
%Gazebo topic
subscriber2 = rosmatlab.subscriber('gazebo/model_states', 'gazebo_msgs/ModelStates',1,node);
subscriber.setOnNewMessageListeners({@function1}); subscriber2.setOnNewMessageListeners({@function2});
% Create a new message of type std_msgs/String.
msg = rosmatlab.message('std_msgs/String',node);
% Set the data field of the message and then publish the message
msg.setData(sprintf('Message created: %s',datestr(now)));
publisher.publish(msg); pause(1);
Originally posted by Sanxano on ROS Answers with karma: 70 on 2014-03-27
I added two lines to ~/.bashrc to make sure roscore has a predictable URI:
export ROS_IP=192.168.1.11 <== your computer's IP
export ROS_MASTER_URI=http://192.168.1.11:11311
To connect in MATLAB:
% Run the rosmatlab setup scripts
addpath([matlabroot '/toolbox/psp/rosmatlab/']);
rosmatlab_SetPath;
rosmatlab_AddClassPath;
% Connect to roscore which should be running in a terminal
node = rosmatlab.node('MATLAB_NODE', '192.168.1.11', 11311);
% Subscribe to the 'state' topic to receive updates on the state.
% The message type is lyap_control/plant
subscriber = rosmatlab.subscriber('state', 'lyap_control/plant', 1, node);
Originally posted by AndyZe with karma: 2331 on 2015-01-04
Comment by dottant on 2015-03-02:
Does it work or not?? I can't subscribe from Matlab to ros topic, it seems to be unidirectional. Please, let me know if you solved it and share the full solution! thanks!!!
Comment by ziyeshanwai on 2015-03-28:
I want to know ,too.I meet the same problem give you a link,maybe can help you link text
Comment by AndyZe on 2015-03-28:
Yeah, it works, guys. Have you tried it? Make sure the ip that you specify with ROS_IP is your computer's current IP.
Comment by ziyeshanwai on 2015-03-29:
Yes,I have tried.I worked!
