I follow the instruction on Skeleton Markers h*ttp://wiki.ros.org/skeleton_markers. Sorry I do not have the right to publish a link, but that package is so cool.
However I encounter some problems (ROS Hydro + Ubuntu 12.10).
When I install it, on command git checkout hydro-devel, it says fatal: Not a git repository (or any parent up to mount point /home) Stopping at filesystem boundary (GIT_DISCOVERY_ACROSS_FILESYSTEM not set). I do not know what does it mean. But I can catkin_make the package...
After installation, I try to run it. however the first method does not work for me, while the second method works well.
UPDATE It works by following answers below. Thank you very much @Pi Robot. However there is a warning. I think it relates to the depth registration. You know, I cannot display registered RGB D image right now. As show in http://answers.ros.org/question/143871/no-register-data-from-kinect/ The log of catkin_make skeleton markers is listed below. The warning is in the last four lines.
rical@rical-CF-19RHRAX1M:~/ros_kinect$ catkin_make Base path: /home/rical/ros_kinect Source space: /home/rical/ros_kinect/src Build space: /home/rical/ros_kinect/build Devel space: /home/rical/ros_kinect/devel Install space: /home/rical/ros_kinect/install
Running command: "cmake /home/rical/ros_kinect/src -DCATKIN_DEVEL_PREFIX=/home/rical/ros_kinect/devel -DCMAKE_INSTALL_PREFIX=/home/rical/ros_kinect/install" in "/home/rical/ros_kinect/build"
-- Using CATKIN_DEVEL_PREFIX: /home/rical/ros_kinect/devel -- Using CMAKE_PREFIX_PATH: /opt/ros/hydro -- This workspace overlays: /opt/ros/hydro -- Using PYTHON_EXECUTABLE: /usr/bin/python -- Using Debian Python package layout -- Using CATKIN_ENABLE_TESTING: ON -- Call enable_testing() -- Using CATKIN_TEST_RESULTS_DIR: /home/rical/ros_kinect/build/test_results -- Found gtest sources under '/usr/src/gtest': gtests will be built -- catkin 0.5.81 -- BUILD_SHARED_LIBS is on -- ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ -- ~~ traversing 1 packages in topological order: -- ~~ - skeleton_markers -- ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ -- +++ processing catkin package: 'skeleton_markers' -- ==> add_subdirectory(skeleton_markers) -- Found GLUT: /usr/lib/i386-linux-gnu/libglut.so
-- skeleton_markers: 1 messages, 0 services DEBUG variable catkin_INCLUDE_DIRS: /opt/ros/hydro/include;/usr/include DEBUG variable OpenNI_INCLUDE_DIRS: /usr/include/ni DEBUG variable GLUT_INCLUDE_DIRS: DEBUG variable orocos_kdl_INCLUDE_DIRS: /usr/include/eigen3;/opt/ros/hydro/include -- Configuring done -- Generating done -- Build files have been written to: /home/rical/ros_kinect/build
Running command: "make -j4 -l4" in "/home/rical/ros_kinect/build"
Scanning dependencies of target std_msgs_generate_messages_cpp Scanning dependencies of target std_msgs_generate_messages_py Scanning dependencies of target geometry_msgs_generate_messages_cpp Scanning dependencies of target geometry_msgs_generate_messages_py [ 0%] [ 0%] Built target geometry_msgs_generate_messages_py [ 0%] Built target std_msgs_generate_messages_cpp Built target geometry_msgs_generate_messages_cpp [ 0%] Built target std_msgs_generate_messages_py Scanning dependencies of target std_msgs_generate_messages_lisp Scanning dependencies of target geometry_msgs_generate_messages_lisp Scanning dependencies of target skeleton_tracker Scanning dependencies of target skeleton_markers_generate_messages_cpp [ 0%] [ 0%] Built target std_msgs_generate_messages_lisp Built target geometry_msgs_generate_messages_lisp [ 14%] Scanning dependencies of target skeleton_markers_generate_messages_lisp Generating C++ code from skeleton_markers/Skeleton.msg Scanning dependencies of target skeleton_markers_generate_messages_py [ 28%] [ 42%] Generating Lisp code from skeleton_markers/Skeleton.msg Generating Python from MSG skeleton_markers/Skeleton [ 57%] [ 57%] Built target skeleton_markers_generate_messages_lisp Generating Python msg init.py for skeleton_markers [ 57%] Built target skeleton_markers_generate_messages_py [ 57%] Built target skeleton_markers_generate_messages_cpp Scanning dependencies of target skeleton_markers_generate_messages [ 57%] Built target skeleton_markers_generate_messages [ 71%] [ 85%] [100%] Building CXX object skeleton_markers/CMakeFiles/skeleton_tracker.dir/src/KinectDisplay.cpp.o Building CXX object skeleton_markers/CMakeFiles/skeleton_tracker.dir/src/KinectController.cpp.o Building CXX object skeleton_markers/CMakeFiles/skeleton_tracker.dir/src/skeleton_tracker.cpp.o In file included from /home/rical/ros_kinect/src/skeleton_markers/src/KinectController.h:5:0, from /home/rical/ros_kinect/src/skeleton_markers/src/KinectController.cpp:4: /usr/include/ni/XnCppWrapper.h: In member function ‘XnStatus xn::SkeletonCapability::RegisterCalibrationCallbacks(xn::SkeletonCapability::CalibrationStart, xn::SkeletonCapability::CalibrationEnd, void*, void*&)’: /usr/include/ni/XnCppWrapper.h:7058:165: warning: call to ‘xnRegisterCalibrationCallbacks’ declared with attribute warning: This function is deprecated: Please use RegisterToCalibrationStart/Complete [enabled by default] /usr/include/ni/XnCppWrapper.h: In member function ‘XnStatus xn::PoseDetectionCapability::RegisterToPoseCallbacks(xn::PoseDetectionCapability::PoseDetection, xn::PoseDetectionCapability::PoseDetection, void*, void*&)’: /usr/include/ni/XnCppWrapper.h:7468:161: warning: call to ‘xnRegisterToPoseCallbacks’ declared with attribute warning: This function is deprecated: Please use PoseDetected and/or OutOfPose callbacks [enabled by default] /usr/include/ni/XnCppWrapper.h: In member function ‘XnStatus xn::Context::InitFromXmlFile(const XnChar*, xn::EnumerationErrors*)’: /usr/include/ni/XnCppWrapper.h:9533:114: warning: call to ‘xnInitFromXmlFile’ declared with attribute warning: This function is deprecated: Please use xnInitFromXmlFileEx() instead [enabled by default] /usr/include/ni/XnCppWrapper.h: In member function ‘XnStatus xn::Context::OpenFileRecording(const XnChar*)’: /usr/include/ni/XnCppWrapper.h:9548:61: warning: call to ‘xnContextOpenFileRecording’ declared with attribute warning: This function is deprecated: Please use xnContextOpenFileRecordingEx() instead [enabled by default] /home/rical/ros_kinect/src/skeleton_markers/src/KinectController.cpp: In member function ‘int KinectController::init(const char*, bool)’: /home/rical/ros_kinect/src/skeleton_markers/src/KinectController.cpp:108:46: warning: call to ‘xn::Context::OpenFileRecording’ declared with attribute warning: This function is deprecated: Use other overload! [enabled by default] /home/rical/ros_kinect/src/skeleton_markers/src/KinectController.cpp:117:44: warning: call to ‘xn::Context::InitFromXmlFile’ declared with attribute warning: This function is deprecated: Use other overload! [enabled by default] /home/rical/ros_kinect/src/skeleton_markers/src/KinectController.cpp:137:158: warning: call to ‘xn::SkeletonCapability::RegisterCalibrationCallbacks’ declared with attribute warning: This function is deprecated: Please use RegisterToCalibrationStart/Complete [enabled by default] /home/rical/ros_kinect/src/skeleton_markers/src/KinectController.cpp:147:115: warning: call to ‘xn::PoseDetectionCapability::RegisterToPoseCallbacks’ declared with attribute warning: This function is deprecated: Please use RegisterToPoseDetected/RegisterToOutOfPose instead [enabled by default] Linking CXX executable /home/rical/ros_kinect/devel/lib/skeleton_markers/skeleton_tracker [100%] Built target skeleton_tracker
Originally posted by pinocchio on ROS Answers with karma: 101 on 2014-03-25
Thanks for the bug report. I was missing a step in the installation instructions: you have to first 'cd skeleton_markers' before doing 'git checkout hydro-devel'. Here are the corrected instructions and I have also updated the ROS Wiki page:
$ cd ~/catkin_ws/src (change to match your catkin workspace directory)
$ git clone https://github.com/pirobot/skeleton_markers.git
$ cd skeleton_markers
$ git checkout hydro-devel
$ cd ~/catkin_ws
$ catkin_make
--patrick
Originally posted by Pi Robot with karma: 4046 on 2014-03-25
Comment by pinocchio on 2014-03-26:
Hi @Pi Robot, Thanks for your help. However, using this new instruction makes skeleton_marker does not work. I mean when I use the old one, Method Two on instruction works, although error occurs on git checkout hydro-devel. When I add cd skeleton_markers and git checkout hydro-devel following the new instruction, error of git checkout hydro-devel disappears, but error appears on catkin_make. Because there is some limit, I revise my question and update the log there. Many thanks.
Comment by Pi Robot on 2014-03-26:
Hi @pinocchio, it looks like you have a problem in your beginner_tutorials package. Try moving that package out of your catkin_ws/src folder for now, then remove the devel, build and install subdirectories beneath catkin_ws so you are starting clean, then re-run catkin_make.
Hi @Pi Robot, I initiate a new workspace, and install skeleton_markers in it. However the same error occurs. The log is posted on the question. Thanks again for your help.
Looks like you might be missing the Glut libraries. Please try 'sudo apt-get install freeglut3 freeglut3-dev' and then re-run catkin_make.
Thank you very much @Pi Robot. It works now, except a warning shown. I think it is related to the depth_registration. You know I cannot enable it to show the registered RGBD image. I post the problem here. http://answers.ros.org/question/143871/no-register-data-from-kinect/
