Hi guys here is a error installing ros_lib any help will appreciated. I'm new with Ros and Ubuntu.
@administrator:/home$ rosrun rosserial_arduino make_libraries.py /sketchbook/libraries/ Exporting to /sketchbook/libraries Traceback (most recent call last): File "/opt/ros/hydro/share/rosserial_arduino/make_libraries.py", line 87, in shutil.copytree(rosserial_arduino_dir+"/src/ros_lib", path+"/ros_lib") File "/usr/lib/python2.7/shutil.py", line 175, in copytree os.makedirs(dst) File "/usr/lib/python2.7/os.py", line 150, in makedirs makedirs(head, mode) File "/usr/lib/python2.7/os.py", line 150, in makedirs makedirs(head, mode) File "/usr/lib/python2.7/os.py", line 157, in makedirs mkdir(name, mode) OSError: [Errno 13] Permission denied: '/sketchbook'
Ubuntu 12.04 ros-hydro
I also try sudo su and them rosrun and here is the error:
juanquy@administrator:/home$ sudo su [sudo] password for juanquy: root@administrator:/home# rosrun rosserial_arduino make_libraries.py /home/sketchbook/librariesrosrun: command not found
Originally posted by juanquy on ROS Answers with karma: 55 on 2014-03-23
You should not rosrun things as root. Instead, either make sure you have write permissions to the /sketchbook/libraries folder, or use a location in in your home, maybe ~/sketchbook/libraries?
Originally posted by demmeln with karma: 4306 on 2014-03-23
Comment by juanquy on 2014-04-02:
Thank you, I just used the root of my home and them cp to /sketchbook/libraries and done. Thank you again
Comment by demmeln on 2014-04-03:
If your problem is solved, please mark an answer as accepted to indicate this to others. Thanks.
