Hi there,
i'm new to this forum and hope to ask my question the right way.
I started to work with ROS. To get used to it i tested some SLAM algorithm to get a occupancy grid map. The first one was gmapping(http:// wiki.ros.org/ gmapping), the second one was hector_mapping(http:// wiki.ros.org/ hector_slam), both worked fine for me.
Now im searching for some other algorithm for comparsion and wanted to ask if you can commend some others. They should be easy to use like gmapping and hector_mapping. Im using laserdata and odometry but its not neccessary that the algorithm using both.
Thanks for your help.
Sascha
Originally posted by GermanStudent on ROS Answers with karma: 11 on 2014-03-18
Probably late to answer I guess, Try rtabmap_ros.
Originally posted by R@m with karma: 98 on 2016-09-10
SLAM Karto (https://github.com/ros-perception/slam_karto) is another option, but it's not well documented on the ROS wiki.
You might also be interested in this paper (I'm not affiliated): "An Evaluation of 2D SLAM Techniques Available in ROS"
Originally posted by spmaniato with karma: 1788 on 2016-09-10
