ROS: groovy OS: ubuntu 12.04
What we are trying to do is have roscore start upon boot (have this working now) and then execute a launch file. I am not a linux person, so I feel I am really not approaching this the right way. Currently, this is what I have attempted:
  1. roscore is launched via a script in /etc/init.d. This is fine.
  2. I want to launch my launch file on boot. Manually, I do it like this: roslaunch rover.launch. It works great.
  3. I would like this to start on boot, so I tried the following: inside new script (boot.sh) - note i disabled password prompt for sudo:
    sudo su - roboops /home/roboops/groovycat/scripts/bootRoverLaunch.sh
    bootRoverLaunch.sh:
    cd /home/roboops/groovycat/ source devel/setup.sh sleep 5 roslaunch rover.launch > /home/roboops/groovycat/scripts/startup.log
  4. I went to "startup applications" and added "bash /home/roboops/groovycat/scripts/boot.sh"
  5. Tried rebooting. Roscore starts, and the launch files executes. However, the nodes malfunction and don't work correctly (They work fine when started using the launch file directly in a terminal window. Oddly, it also works fine if I log out and back in once)
More specifically, here is the problem when using the above script to launch:
I am trying to run two nodes:
-joystick node (publishes joy topic) -motor control node (listens to joy topic and outputs commands to motor controllers via serial)
Joystick node starts successfully and If I do rostopic echo joy, I can see the values. Motor control node is listed as running but if I run roswtf it says:
Found 3 error(s).
ERROR Could not contact the following nodes:
 * /Drivetrain
ERROR The following nodes should be connected but aren't:
 * /Drivetrain->/rosout (/rosout)
ERROR Errors connecting to the following services:
 * service [/Drivetrain/get_loggers] appears to be malfunctioning: Unable to communicate with service [/Drivetrain/get_loggers], address [rosrpc://Rover:58631]
 * service [/Drivetrain/set_logger_level] appears to be malfunctioning: Unable to communicate with service [/Drivetrain/set_logger_level], address [rosrpc://Rover:58631]
The idea is, I need everything to automatically start on power-up. There will be no input devices/monitor connected to it when it is in use.
Originally posted by rb on ROS Answers with karma: 130 on 2014-03-15
3 Answers 3
We recommend using the robot_upstart package we developed. It's simple, seems to do everything you need, and has already been deployed on dozens of robots.
Originally posted by Ryan with karma: 3248 on 2014-03-17
Comment by Andrew.A on 2014-05-29:
I notice the package only has a hydro/devel branch. Does this work for groovy?
Comment by mikepurvis on 2014-07-07:
Hi Andrew, yes, robot_upstart should work with groovy as well as hydro, as long as you don't mind doing a source install of it in your workspace.
Comment by julien on 2015-02-02:
Hi Mike,
I'm also trying to use robot_upstart since 3hours without results.... is it possible to use this package with indigo???
Tks
Comment by Ryan on 2015-02-05:
@julien: I'm not Mike, but I know we use it to run our Jackal, which is Indigo-only. Have you tried using
sudo apt-get install ros-indigo-robot-upstart
to install it? Instructions to use it are on both the ROS wiki and its github page.
Comment by Cerin on 2016-08-14:
Note, this package is no longer supported on Kinetic.
Comment by kmhallen on 2017-04-09:
Support for Kinetic has been added
I start my roslaunch on start up using cron (http://wiki.ubuntuusers.de/Cron) and screen (http://wiki.ubuntuusers.de/screen).
I have a /home/user/autostart/autostart_screens.sh that get executed by cron @reboot (Meaning whenever the PC is booted). You can set these startup files via crontab command. See crontab --help. My current crontab -l gives:
# Edit this file to introduce tasks to be run by cron.
# Each task to run has to be defined through a single line
# indicating with different fields when the task will be run
# and what command to run for the task
# To define the time you can provide concrete values for
# minute (m), hour (h), day of month (dom), month (mon),
# and day of week (dow) or use '*' in these fields (for 'any').#
# Notice that tasks will be started based on the cron's system
# daemon's notion of time and timezones.
# Output of the crontab jobs (including errors) is sent through
# email to the user the crontab file belongs to (unless redirected).
# For example, you can run a backup of all your user accounts
# at 5 a.m every week with:
# 0 5 * * 1 tar -zcf /var/backups/home.tgz /home/
# For more information see the manual pages of crontab(5) and cron(8)
# m h  dom mon dow   command
@reboot bash /home/user/autostart/autostart_screens.sh
My autostart_screens.sh starts and detaches two screen sessions and logs any thing happening inbetween to a log file. It looks like:
# !/bin/bash
LOG_FILE=/home/user/autostart/logs/log_autostart_screens.txt
echo "" >> ${LOG_FILE}
echo "#############################################" >> ${LOG_FILE}
echo "Running autostart_screens.sh" >> ${LOG_FILE}
echo $(date) >> ${LOG_FILE}
echo "Logs:" >> ${LOG_FILE}
set -e
set -v
screen -d -m bash /home/user/autostart/start_roscore.sh
screen -d -m bash /home/user/autostart/start_roslaunch.sh
} &>> ${LOG_FILE}
Note that it is not blocking as it just starts the screens.
The start_roscore.sh looks like:
# !/bin/bash
LOG_FILE=/home/user/autostart/logs/log_start_roscore.txt
echo "Running start_roscore.sh" >> ${LOG_FILE}
set -e
source /opt/ros/hydro/setup.bash
source /home/user/workspace/ros_hydro/catkin/devel/setup.bash
export ROS_WORKSPACE=/home/user/workspace/ros_hydro/catkin
export ROS_MASTER_URI=http://192.168.1.10:11311/ ##e. g. Master
export ROS_IP=192.168.1.15                   ##e. g. Own IP
sleep 5
} &>> ${LOG_FILE}
set -v
roscore
} &>> ${LOG_FILE}
The start_roslaunch.sh looks like:
# !/bin/bash
LOG_FILE=/home/user/autostart/logs/log_start_roslaunch.txt
echo "Running start_roslaunch.sh" >> ${LOG_FILE}
set -e
sleep 8
} &>> ${LOG_FILE}
set -v
roslaunch my_pkg my_launch.launch
} &>> ${LOG_FILE}
All logs go to /home/user/autostart/logs. After start youn can verify your ros being up using rosnode list. You can monitor your screens using screen -ls. Note that the timeout in start_roslaunch.sh is longer than in start_roscore.sh. In order for shutting down the nodes on my computer if I want to use it for something else I use this script:
# !/bin/bash
for session in $(screen -ls | grep -o '[0-9]\{5\}')
do
    screen -S "${session}" -X quit;
done
It sends a Crlt+C to all running screen sessions.
Originally posted by Wolf with karma: 7555 on 2014-03-17
Why are you running both roscore and roslaunch in separate scripts? roslaunch will automatically run roscore if needed.
I start my roscore on boot simply by adding this line in "/etc/rc.local" before "exit0":
su pi -c "source /home/pi/YOURWS/devel/setup.sh ; roscore  > /dev/null 2>&1 &"
the "> /dev/null" means its logs dont get stored anywhere and "&" at the end means it starts in the background. You cant start roscore in root mode, that's why "su pi -c" is at the start of the command. Replace "/home/pi/YOURWS" with your workspace name and destination.
Comment by elpidiovaldez on 2018-05-24:
Works, and it's simple ! I have spent hours trying to use robot_upstart, but it needs too many files and devices to have their permissions changed. I used a launch file: su ubuntu -c "source /home/ubuntu/catkin_ws/devel/setup.sh ; roslaunch biped biped_robot.launch > /dev/null 2>&1 &"
