Hi everyone.
I sincerely apologize if my question sounds stupid or has been answered before (I searched the forum and have read the tutorials but didn't find my answer). I'm currently building a URDF file for our robot using xacro. What I've noticed is that the origin of the frame of reference of every link is in the center of that link. For example when modeling hands, the tf will point to the center of the hand. I wanted to change this so tf frames will represent joints of hands and other parts of the robot, and not the middle of link. How is that possible to do?
Btw the current robot model is:
<?xml version="1.0"?>
<robot xmlns:xacro="----KARMA INSUFFICIENT" name="my_robot">
<!-- base cylinder properties -->
<xacro:property name="cyl_radius"                           value=".5"/>
<xacro:property name="cyl_height"                           value=".3"/>
<xacro:property name="cyl_buttom"                           value=".2"/> <!-- NOTE: not used currently -->
<!-- wheel properties -->
<xacro:property name="wheel_height"                         value=".2"/>
<xacro:property name="wheel_dist_to_center"                 value=".2"/>
<!-- laserscanner properties -->
<xacro:property name="laserscanner_dist_to_center"          value=".2"/>
<xacro:property name="laserscanner_height"                  value=".2"/>
<!-- body properties -->
<xacro:property name="body_dist_to_center"                  value=".35"/>
<xacro:property name="body_height"                          value="1.5"/>
<xacro:property name="body_width"                           value="0.07"/>
<!-- shoulder cylinder properties -->
<xacro:property name="shoulder_to_body_distance_x"          value=".15"/>
<xacro:property name="shoulder_rec_size"                    value=".07"/>
<xacro:property name="shoulder_length"                      value=".5"/>
<xacro:property name="shoulder_min_height"                  value=".8"/>
<xacro:property name="shoulder_max_height"                  value=".2"/>
<xacro:property name="max_shoulder_leveler_velocity"        value=".2"/>
<xacro:property name="max_shoulder_leveler_effort"          value=".2"/>
<!-- hands properties -->
<xacro:property name="upper_arm_length"                     value=".5"/>
<xacro:property name="forearm_length"                       value=".2"/>
<xacro:property name="upper_arm_min_angle"                  value=".2"/>
<xacro:property name="upper_arm_max_angle"                  value=".2"/>
<xacro:property name="forearm_min_angle"                    value="-4"/>
<xacro:property name="forearm_max_angle"                    value="4"/>
<xacro:property name="arm_max_effort"                       value=".2"/>
<xacro:property name="arm_max_velocity"                     value=".2"/>
<!-- Starting the robot definition -->
<link name="base_link">
    <visual>
        <geometry>
            <cylinder radius="${cyl_radius}" length="${cyl_height}"/>
        </geometry>
        <material name="blue">
            <color rgba="0 0 .8 1"/>
        </material>
    </visual>
    <collision>
        <geometry>
        </geometry>
        <origin xyz="0 0 0" rpy="0 0 0"/>
    </collision>
</link>
<joint name="base_to_body_joint" type="fixed">
    <parent link="base_link"/>
    <child link="body"/>
    <origin xyz="${body_dist_to_center} 0 ${(cyl_height + body_height)/2}"/>
</joint>
<link name="body">
    <visual>
        <geometry>
            <box size="${body_width} ${body_width} ${body_height}"/>
        </geometry>
        <material name="red">
            <color rgba="1 0 0 1"/>
        </material>
    </visual>
    <collision>
        <geometry>
        </geometry>
    </collision>
</link>
<joint name="shoulder_leveler" type="prismatic">
    <parent link="body"/>
    <child link="shoulder"/>
    <origin xyz="${shoulder_to_body_distance_x} 0 ${(shoulder_min_height + shoulder_max_height - body_height)/2}" rpy="0 0 0"/>
    <axis xyz="0 0 1"/>
    <limit lower="${shoulder_min_height}" upper="${shoulder_max_height}"
           effort="${max_shoulder_leveler_effort}" velocity="${max_shoulder_leveler_velocity}" />
</joint>
<link name="shoulder">
    <visual>
        <geometry>
            <box size="${shoulder_rec_size} ${shoulder_length} ${shoulder_rec_size}"/>
        </geometry>
        <material name="red_1">
            <color rgba="0.5 0 0 1"/>
        </material>
    </visual>
    <collision>
        <geometry>
        </geometry>
    </collision>
</link>
<xacro:macro name="hand" params="prefix reflect">
    <joint name="${prefix}_shoulder_joint" type="revolute">
        <parent link="shoulder"/>
        <child link="${prefix}_upper_arm"/>
        <axis xyz="0 1 0"/>
        <origin xyz="0 ${reflect * shoulder_length/2} ${-upper_arm_length/2}"/>
        <limit lower="${upper_arm_min_angle}" upper="${upper_arm_max_angle}"
                effort="${arm_max_effort}" velocity="${arm_max_velocity}" />
    </joint>
    <link name="${prefix}_upper_arm">
        <visual>
            <geometry>
                <box size="0.07 0.07 ${upper_arm_length}"/>
            </geometry>
            <material name="green">
                <color rgba="0 1 0 1"/>
            </material>
        </visual>
    </link>
</xacro:macro>
<xacro:hand prefix="left" reflect="-1"/>
<xacro:hand prefix="right" reflect="1"/>
I apologize for the long post.
Originally posted by Kourosh on ROS Answers with karma: 23 on 2014-03-14
Ok it took me some time to figure out the solution to this problem as well.
When you're designing your robot you have different kind of things to think about.
First of all your place all of you tf frames. Tf frames are independent of the actual robot appearance. The hand frame could not be "on" the hand (but it would not be very handy though).
That's what you do when you write something like
    <axis xyz="0 1 0"/>
</joint>
There is the origin element define where your frame is going to be. You thus defined the position of each tf frame of the robot
Now you want to draw the robot itself. You have to use the visual element for that. For example
    <visual>
        <geometry>
        </geometry>
        </material>
    </visual>
</link>
Here in your code you are missing an origin element like this one :
      <origin rpy="0 0 0" xyz="0 0 ${hand_length/2}"/>
This element will define the origin of the visual shape compared to the tf frame. The rpy define the rotation while the xyz define the translations. So you can just move the visual element around the tf frame to have it wherever you want.
To summarize :
First you define the tf frame place. The visual shape is going to be centered on that shape so you use the origin element to place it in space, compared to the tf frame it depend on.
Hope I have been clear enough.
Originally posted by Maya with karma: 1172 on 2014-03-14
Post score: 5
Comment by Kourosh on 2014-03-22:
Thank you very much. Everything is now much simpler because of your suggestion.
