I would like to try running a CNC mill using ROS. More specifically I want to use RVIZ to help us visualize a CNC task prior to running it live on the CNC. My understanding is that one of the first step in this process is exporting my robot URDF using the SolidWorks URDF exporter. The exporter seems geared towards exporting revolute joints but doesn't seem to have any functionality to setup linear actuators / prismatic joints. Is this possible? If so what are the steps for specifying a linear actuator? If someone can point me the way I would love to write a tutorial about this.
Here are a couple of example 3 axis gantries that use linear actuators similar to the one I am working with:
- GrabCAD: http://grabcad.com/library/damki-cnc-router-1
- ShapeOKO: http://3dwarehouse.sketchup.com/model.html?id=f6ed9052b5de9a00dbd8f267ad6945df
Originally posted by kscottz on ROS Answers with karma: 209 on 2014-03-14
Comment by gvdhoorn on 2014-03-26:
Not really an answer, but AFAIK the exporter should support setting up prismatic joints. Not sure about the quality / correctness of the exported URDF then though.
