Hi everyone. I'm doing this thing (youbot ros-hydro-wrapper-for-kuka-youbot) trying to make youbot by Kuka working and there's an error on the last "$ catkin_make".
$ cd ~/catkin_ws/src
    $ git clone github.com /youbot/youbot_driver_ros_interface.git -b hydro-devel
$ cd ..
$ catkin_make
$ sudo setcap cap_net_raw+ep devel/lib/youbot_driver_ros_interface/youbot_driver_ros_interface
it's my first time with Ubuntu and ROS, so I don't really know what gone wrong.
CMake Error at /opt/ros/hydro/share/catkin/cmake/catkinConfig.cmake:72 (find_package): Could not find a package configuration file provided by "brics_actuator" with any of the following names:
brics_actuatorConfig.cmake
brics_actuator-config.cmake
Add the installation prefix of "brics_actuator" to CMAKE_PREFIX_PATH or set "brics_actuator_DIR" to a directory containing one of the above files. If "brics_actuator" provides a separate development package or SDK, be sure it has been installed. Call Stack (most recent call first):
youbot_driver_ros_interface/CMakeLists.txt:5 (find_package)
-- Configuring incomplete, errors occurred! make: *** [cmake_check_build_system] Error 1 Invoking "make cmake_check_build_system" failed
Originally posted by runout on ROS Answers with karma: 3 on 2014-03-10
It looks like the youbot driver requires the brics_actuator package but you have not installed it on your system or put it in your workspace. You'll need to resolve that dependency before you can build that package.
Originally posted by tfoote with karma: 58457 on 2014-03-10
Comment by runout on 2014-03-29:
Thanks, well the next question will be: how to do that. I've found brics_actuator git, but I really new at linux so I have no idea what to do with that. :(
found it. That's what I was needed. brics_actuator. [$ sudo apt-get install ros-hydro-brics-actuator] pr2_msgs. [$ sudo apt-get install ros-hydro-pr2-msgs]
Now I got new problem with: [youbot_driver.launch] is neither a launch file in package [youbot_driver_ros_interface] nor is [youbot_driver_ros_interface] a launch file name But I guess that's another question.
Comment by ratneshmadaan on 2014-05-15:
$ sudo apt-get install ros-hydro-youbot-driver-ros-interface
I edited the youbot-ethercat config file from eth0 to eth1 (path is /opt/ros/hydro/share/youbot_driver/config, you'll need sudo access to edit it). But I am getting an error [ERROR] [1400149466.933178411]: No EtherCAT connection: [FATAL] [1400149466.933450442]: No socket connection on eth1 Excecute as root (I have the manipulator at eth1 only.) Help please?
Comment by CroCo on 2022-08-18:
For Simulation, how to bypass that error? I'm not intended to use the real hardware. Any suggestions!
