I was wondering if it is possible to send data over a network to another computer using TCP. One computer is running ROS and the other is not.
Originally posted by iceburg6628 on ROS Answers with karma: 16 on 2014-03-05
Yes, this is possible. You just have to use your custom TCP communication code inside a ROS node. You can then, for example receive data on a ROS topic via a callback, process it, and send it out to the non-ROS computer using your custom TCP connection setup.
Originally posted by Stefan Kohlbrecher with karma: 24361 on 2014-03-05
Comment by iceburg6628 on 2014-03-05:
Thank you, I wasn't sure if their was a built in package.
Comment by Yuichi Chu on 2014-03-06:
How should I edit the CMakelists.txt if my program includes other libs and other .h files?Thank you ...
Comment by Alvaro Salcedo on 2015-04-21:
I have the same question. Did you solve it? Thanks a lot.
