Hello , I have been trying to get the exploration stack working on hydro ( catkin ) and for the most part it works, but whenever I try to include the navfn/navfn_ros.h in my header file as show on wiki.ros.org/navfn, and run catkin_make, I get the following error :
 In file included from /home/vicos/explore_ws/src/explorer/src/FrontierExplorer.cpp:1:0:
/home/vicos/explore_ws/src/explorer/include/explorer/FrontierExplorer.h:19:29: fatal error: navfn/navfn_ros.h: No such file or directory
compilation terminated.
Here is a part of my header file :
#ifndef FRONTIER_EXPLORATION_H
#define FRONTIER_EXPLORATION_H
#include <ros/ros.h>
#include <visualization_msgs/Marker.h>
#include <boost/bind.hpp>
#include <boost/thread.hpp>
#include <move_base_msgs/MoveBaseAction.h>
#include <actionlib/client/simple_action_client.h>
#include <vector>
#include <costmap_2d/costmap_2d_ros.h>
#include <costmap_2d/costmap_2d.h>
#include <geometry_msgs/PoseStamped.h>
#include <nav_msgs/GetMap.h>
#include <explorer/FrontierFinder.h>
#include <explorer/Visualizer.h>
#include <navfn/navfn_ros.h>
#include <navfn/navfn.h>
CMakeLists.txt :
project(explorer)
  actionlib
  costmap_2d
  geometry_msgs
  move_base_msgs
  navfn
  nav_core
  roscpp
  visualization_msgs
  tf
 find_package(Boost REQUIRED COMPONENTS system)
catkin_package(
  INCLUDE_DIRS include
  LIBRARIES ${PROJECT_NAME} #explorer
  CATKIN_DEPENDS
   actionlib
   costmap_2d
   geometry_msgs
   move_base_msgs
   navfn
   roscpp
   visualization_msgs
   tf
include_directories(
    include
  ${catkin_INCLUDE_DIRS}
add_executable(FrontierExplorer src/FrontierExplorer.cpp src/FrontierFinder.cpp src/Visualizer.cpp)
target_link_libraries(FrontierExplorer ${catkin_LIBRARIES})
package.xml :
<?xml version="1.0"?>
<package>
  <name>explorer</name>
  <version>0.0.1</version>
  <description>The explorer package</description>
  <maintainer email="[email protected]">vicos</maintainer>
  <license>BSD</license>
  <buildtool_depend>catkin</buildtool_depend>
  <build_depend>actionlib</build_depend>
  <build_depend>costmap_2d</build_depend>
  <build_depend>geometry_msgs</build_depend>
  <build_depend>move_base_msgs</build_depend>
  <build_depend>navfn</build_depend>
  <build_depend>roscpp</build_depend>
  <build_depend>visualization_msgs</build_depend>
  <build_depend>tf</build_depend>
  <run_depend>actionlib</run_depend>
  <run_depend>costmap_2d</run_depend>
  <run_depend>geometry_msgs</run_depend>
  <run_depend>move_base_msgs</run_depend>
  <run_depend>navfn</run_depend>
  <run_depend>roscpp</run_depend>
  <run_depend>visualization_msgs</run_depend>
  <run_depend>tf</run_depend>
</package>
running rospack find navfn returns
/opt/ros/hydro/share/navfn
and if I run rospack depends explorer (my modified exploration stack)
genmsg
gencpp
genlisp
genpy
message_generation
catkin
console_bridge
cpp_common
rostime
roscpp_traits
roscpp_serialization
message_runtime
std_msgs
actionlib_msgs
rosbuild
rosconsole
rosgraph_msgs
xmlrpcpp
roscpp
rosgraph
rospack
roslib
rospy
rosclean
rosmaster
rosout
rosparam
roslaunch
rosunit
rostest
actionlib
rosbag_storage
topic_tools
rosbag
rosmsg
rosservice
dynamic_reconfigure
geometry_msgs
sensor_msgs
message_filters
rostopic
rosnode
roswtf
tf2_msgs
tf2
tf2_py
tf2_ros
tf
angles
laser_geometry
nav_msgs
map_msgs
pcl_msgs
pcl_conversions
bond
smclib
bondcpp
class_loader
pluginlib
nodelet
nodelet_topic_tools
pcl_ros
visualization_msgs
voxel_grid
costmap_2d
move_base_msgs
nav_core
navfn
both of which suggest that the navfn is present and correctly configured on the system and the move_base node ( which seems to use navfn ) works perfectly. So, why do I get the error ?
Thank you in advance for answering my question / helping with my problem !
Originally posted by luka-s on ROS Answers with karma: 33 on 2014-03-05
The header you want is one level too deep in the include hierarchy: navfn/navfv/navfn_ros.h instead of navfn/navfn_ros.h, etc.
That looks like a bug in navfn to me. The Fuerte version put it where one would expect.
You can probably work around this temporarily by adding an extra navfn/ to your #include lines, but it needs to be fixed and should be reported as an issue.
EDIT: As Dirk said, this bug has been fixed in the source tree but still not released to the Ubuntu binary package repository. As a work-around, you can check out the source into your workspace from the https://github.com/ros-planning/navigation.git hydro-devel branch.
Originally posted by joq with karma: 25443 on 2014-03-05
Comment by Dirk Thomas on 2014-03-05:
The bug has been fixed in https://github.com/ros-planning/navigation/commit/25f6ef8b7008bc383fb22aec84280e4d107ac8d5 but no new release has been made since then. I added a comment (https://github.com/ros-planning/navigation/commit/166614ca97a637cf525c930d81fcb7b80c48d08c#commitcomment-5575488) - hopefully the maintainers will release a new version into hydro soon.
Comment by luka-s on 2014-03-07:
Thank you, the suggested approach works :). Sort of. Now I can use navfn's planner but the rest of code stops working ..and I can't really figure out why. So I can either use navfn or, remove the navigation source from my workspace and try to run my code without it, like before. I hope the repair the headers soon
