On the turtlebot I am trying to launch the amcl demo after launching the gmapping demo, but without shutting down all of ros.
Usually I can get the gmapping to work (that's the first demo I test) and then the amcl will partially work. I can load a map using 'map_store' and then see the map on the rviz screen. I also can usually see the turtlebot on the rviz screen. I have trouble directing the turtlebot, though, and I don't exactly know why.
When I look at the RobotModel listing under the 'Displays' box in rviz it's red, and the cause is that the tf's from all the components are red. (base_footprint, base_link, etc., all red). They all say 'No transform from [base_footprint] to [map]'. When I execute view_frames and look at the pdf it says "no tf data received". When I type rostopic list '/tf' comes up as one of my topics. Is there something I can start that will restart the tf data in the turtlebot?
If I don't start gmapping first I can usually load a map and direct the turtlebot with /initialpose, etc.
Originally posted by david.c.liebman on ROS Answers with karma: 125 on 2014-02-27
Try using multiple terminals: start the basic turtlebot nodes, i.e. turtlebot_bringup/minimal.launch in the first terminal and the app, e.g. make a map, in a second demo. Then, when you like to launch a different set of nodes/app, only kill the launcher in the second terminal and execute the new launcher.
If you have further nodes, which manage data and need to remain active, e.g. map_store, use more terminals and make sure to exclude those nodes from your app launcher.
Hope this helps!
PS: You might want to take a look at the rocon_app_manager package. The app manager handles the starting and stopping of rapps (robot apps). We use it frequently on our turtlebots for creating and navigating a map as well as teleop.
Originally posted by bit-pirate with karma: 2062 on 2014-03-05
Comment by bit-pirate on 2014-03-30:
If your problem has been solved, please select the best answer thereby marking your question as answered.
