I'm trying to install hydro by following the instructions on the wiki, but when I get to
$ rosdep install --from-paths src --ignore-src --rosdistro hydro -y --os=debian:wheezy
I get
E: Unable to locate package ros-hydro-roscpp-serialization
After some brief experimentation with apt-get, I determined that I can't seem to access any ros packages. How can I resolve this? Sorry, I'm new to linux.
Originally posted by JumpJet27 on ROS Answers with karma: 3 on 2014-02-27
The easyest way to get ROS work on Raspberry is following this instruction, however it is groovy and not hydro:
https://www.willowgarage.com/blog/2013/06/27/getting-groovy-raspberry-pi http://wiki.ros.org/groovy/Installation/Raspbian
I have it running on the raspberry and it works well. As you are new to linux I definitely recommend first trying the groovy version, as it is much quicker and easier to set up on the raspberry (no need to build the packages from source yourself).
Originally posted by Johannes Jaegers with karma: 70 on 2014-02-28
Comment by JumpJet27 on 2014-02-28:
Thanks, I was able to run it with this.
