Hello,
I have a youbot running Ubuntu 12.04 LTS and ROS Hydro. I installed the ros-hydro-youbot-driver and ros-hydro-youbot-driver-ros-interface packages. When I try to start the ros driver using roslaunch youbot_driver_ros_interface youbot_driver.launch I get the following error message which relates to [1]
    core service [/rosout] found
    /opt/ros/hydro/lib/youbot_driver_ros_interface/youbot_driver_ros_interface: error while loading shared libraries: process[youbot_driver-1]: started with pid [3765]
    libtf.so: cannot open shared object file: No such file or directory
    [youbot_driver-1] process has died [pid 3765, exit code 127, cmd /opt/ros/hydro/lib/youbot_driver_ros_interface/youbot_driver_ros_interface base/joint_states:=joint_states arm_1/joint_states:=joint_states __name:=youbot_driver __log:=/home/youbot/.ros/log/cb1447ea-9df2-11e3-9357-0022697f602c/youbot_driver-1.log].
    log file: /home/youbot/.ros/log/cb1447ea-9df2-11e3-9357-0022697f602c/youbot_driver-1*.log
    all processes on machine have died, roslaunch will exit
    shutting down processing monitor...
    ... shutting down processing monitor complete
    done
Note that before I got this error message I also had a different problem with the package: I had to set the ethernet capabilites like described in the building from source section (2.2.2) here: [2] This might be a bug or could be related to this error.
After executing ldconfig /opt/ros/hydro/lib I now get the following error message:
[ INFO] [1393319937.340360990]: Configuration file path: /opt/ros/hydro/share/youbot_driver/config
[ INFO] [1393319937.364843922]: Initializing EtherCAT on eth0 with communication thread
[FATAL] [1393319937.388841667]: No EtherCAT slaves found!
[ERROR] [1393319937.389182353]: Base "youbot-base" could not be initialized.
[ INFO] [1393319937.389486163]: Configuration file path: /opt/ros/hydro/share/youbot_driver/config
[FATAL] [1393319937.392086845]: No socket connection on eth0
Excecute as root
[ERROR] [1393319937.392452185]: Arm "youbot-manipulator" could not be initialized.
[ INFO] [1393319937.392667785]: System has 0 initialized arm(s).
[ WARN] [1393319937.393588013]: ../config/youbot-ethercat.cfg file not found
terminate called after throwing an instance of 'youbot::FileNotFoundException'
  what():  ../config/youbot-ethercat.cfg file not found
[youbot_driver-1] process has died [pid 5955, exit code
Originally posted by Jabro on ROS Answers with karma: 5 on 2014-02-24
Comment by Jabro on 2014-02-24:
adding export LD_LIBRARY_PATH="/opt/ros/hydro/lib/libtf.so" to zshrc/bashrc also didn't help.
Hi, the debian package for the youbot-driver-ros-interface did not work yet because of missing run time dependencies. WIth the next ROS debian update cycle hopefully this should be fixed.
So far it is recommended to compile it yourself, as described here
The second problem with the error "No socket connection on eth0" is usually due to
  • forgot "setcap" command for the youbot_driver_ros_interface executable
  • another port than eth0 is connected (see here)
  • hardware issue with cabling, emergency stop etc.
If you did the first thing and still does not work, you might want to send a message to [email protected] as it is probably not related to ROS anymore.
Originally posted by praman2s with karma: 31 on 2014-02-25
Comment by praman2s on 2014-02-25:
We are not able to edit the answer, same answer posted twice. Solution offered by Walter Nowak.
