Hi everyone,
I'm facing an error when trying to build the tutorial on the pluginlib.
I updated my CMakeLists.txt, package.xml and created a polygon_loader.xml as described in the tutorial, but when I try to build the project, it fails stating that in [my_workspace]/pluginlib_tutorials_/src/polygon_loader.cpp the included header file pluginlib_tutorials_/polygon_base.h could not be found.
The funny thing is, if I change my CMakeLists.txt by adding the line
 target_link_libraries(polygon_loader polygon_plugins)
my polygon_loader.cpp is fine, but my polygon_plugins.cpp throws the previous mentioned error. It seems I missed some configuring in the ROS toolchain I guess. Could please someone help me out?
Thanks in advance,
Roberto
P.S.: Here are the relevant fragments, if something is missing, please ask!
My file structure:
catkin_ws_plugins/
-> build
-> devel
-> src
--> CMakeList.txt
--> pluginlib_tutorials_
---> CMakeLists.txt
---> package.xml
---> polygon_plugins.xml
---> include
----> pluginlib_tutorials_
-----> polygon_base.h
-----> polygon_plugins.h
---> src
-----> polygon_loader.cpp
-----> polygon_plugins.cpp
catkin_ws_plugins/src/pluginlib_tutorials_/CMakeLists.txt:
project(pluginlib_tutorials_)
    pluginlib
    roscpp
catkin_package()
include_directories(
    ${catkin_INCLUDE_DIRS}
add_library(polygon_plugins src/polygon_plugins.cpp)
add_executable(polygon_loader src/polygon_loader.cpp)
target_link_libraries(polygon_loader ${catkin_LIBRARIES})
catkin_ws_plugins/src/pluginlib_tutorials_/package.xml (only the changes):
<export>
    <pluginlib_tutorials_ plugin="${prefix}/polygon_plugins.xml" />
</export>
catkin_ws_plugins/src/pluginlib_tutorials_/polygon_plugins.xml:
<library path="lib/libpolygon_plugins">
    <class type="polygon_plugins::Triangle" base_class_type="polygon_base::RegularPolygon">
         <description>This is a triangle plugin</description>
    </class>
    <class type="polygon_plugins::Square" base_class_type="polygon_base::RegularPolygon">
         <description>This is a square plugin</description>
    </class>
</library>
Last but not least the line where the error occurs in
catkin_ws_plugins/src/pluginlib_tutorials_/src/polygon_loader.cpp
#include <pluginlib_tutorials_/polygon_base.h>
Originally posted by bnm-rc on ROS Answers with karma: 22 on 2014-02-17
You need to add your local include directory to the include_directories in your CMakeLists.txt
It shold look more like:
    include
Originally posted by tfoote with karma: 58457 on 2015-03-03
