I'm using AR.Drone with Flight Recorder (witch enable geolocation using the GPS module).
I installed ardrone_autonomy and very pleased with it. But there is no GPS data in topics published.
However, using QGroundControl, I can connect to AR.Drone and get GPS data in GLOBAL_POSITION_INT packet, so I can get GPS data in my program with MAVLINK.
The problem is that I can't use ardrone_autonomy and MAVLINK connection simultaniously. When I start ardrone_autonomy, I loose connection in QGroundControl (MAVLINK).
So my question is about possibility of reading GPS data from AR.Drone with ardrone_autonomy or using ardrone_autonomy simultaniously with MAVLINK connection?
Originally posted by Rr on ROS Answers with karma: 15 on 2014-02-10
As both @jjwiseman and @jcerruti mentioned, there is experimental support for GPS through "Parrot Flight Recorder" peripheral in ardrone_autonomy driver. It publishes data received from GPS and exposes a service to do GPS based waypoint navigation on-board. GPS Support section of gps-waypoint branch documentation provides more information.
Update: GPS support was added to the driver by patching the official SDK. Therefor, it's possible to trigger on-board GPS based waypoint navigation with the driver while simultaneously access video footage over Wifi.
Originally posted by Mani with karma: 1704 on 2015-05-15
Some quick research suggests that this isn't possible with the existing drivers:
  • ardrone_autonomy is built on the ardrone SDK, which doesn't appear to support the new GPS module. Probably a dead end.
  • roscopter and mavlink_ros are based on the mavlink libraries and communication protocol which supports the GPS, but only appear to support communication over a serial port. You could probably extend this to support IP communication to support the AR.Drone.
Originally posted by ahendrix with karma: 47576 on 2014-02-12
Comment by jjwiseman on 2014-05-06:
It looks like support for GPS is being added to ardrone_autonomy. See https://github.com/AutonomyLab/ardrone_autonomy/pull/95 and https://github.com/AutonomyLab/ardrone_autonomy/tree/gps
Comment by Mani on 2015-05-23:
Please check my answer about GPS support with the official SDK.
