Hi,
Tried three different computers, two different USB-2-Serial cables, but it never works. There is output on the screen, then a warning, followed by the iRobot Create being turned off with a single beep. Using ROS Hydro on Ubuntu 12.04 64-bit, with a Kinect on top of the iRobot Create.
[WARN] [WallTime: 1391659582.260008] Create : robot not connected yet, sci not available
The irobot_create_2_1 bumpGo.py demo DOES however work, on the same system and hardware.
Full screen output here at gist.github.com / Alex-van-der-Peet / 8838247 (had to break it up, not allowed to post links). We set the environment variables specific to our robot:
export TURTLEBOT_BASE=create export TURTLEBOT_STACKS=circles export TURTLEBOT_3D_SENSOR=kinect
Thanks,
Alex
Originally posted by elrapido80 on ROS Answers with karma: 1 on 2014-02-05
Probably the create has timed out/turned itself off. SImilar question as here: http://answers.ros.org/question/161321/turtlebot_bringupwarncreate-robot-not-connected-yet-sci-not-available/
Originally posted by tfoote with karma: 58457 on 2014-05-05
