No, it's not possible to set different polling rates for different sets of servos connected to the same serial bus. It would increase traffic on the serial bus and decrease the maximum polling rate possible. Right now we are just asking to get the updated info on all motors in one go. You could split the leg servos and connect them separately which would also increase the maximum feedback rate as you have less motors on the line to collect info from.
Originally posted by arebgun with karma: 2121 on 2014-02-05
Comment by sertar on 2014-02-05:
Thank you for your fast answer.
Is it possible though to turn on and off some controller dynamically ? i tried with the stop_controller service but it does not improve the polling rate of motors still turned on.
Comment by arebgun on 2014-02-07:
I am not sure, it depends on how many motors are connected, if you have 10 and you disable 1, it is unlikely you will see a significant difference.
Comment by sertar on 2014-02-08:
No i have 30 and i disable 15. if i launch a different manager with only the remaining 15 i see a difference but not when i shut them down with stop_controller (i see on rqtgraph that the controllers are off).
Comment by arebgun on 2014-02-10:
Right, the motors are polled at startup and then that list is not changed until the node is shut down. I think it would be possible to modify this list of motors at runtime and only query the motors associated with started joints. Could you open a feature enhancement ticket on github?
