I'm trying to compile ROS on a Raspberry Pi (Raspbian) following these Debian installation instructions and got to the point to compile ROS, which fails at compiling opencv with undefined reference to 'header':
[ 97%] Built target opencv_videostab
[ 98%] Built target opencv_haartraining_engine
Linking CXX executable ../../bin/opencv_createsamples
../../lib/libopencv_highgui.so.2.4.6: undefined reference to `header'
collect2: ld returned 1 exit status
make[2]: *** [bin/opencv_createsamples] Error 1
make[1]: *** [apps/haartraining/CMakeFiles/opencv_createsamples.dir/all] Error 2
make: *** [all] Error 2
<== Failed to process package 'opencv2':
  Command '/home/ilagi/ros_catkin_ws/install_isolated/env.sh make -j1 -l1' returned non-zero exit status 2
I googled to try to figure out what header file might be missing, but unfortunately didn't get anywhere.
I hope somebody will have an idea about at least the directions to go from here.
Thanks
Originally posted by evk02 on ROS Answers with karma: 218 on 2014-02-04
I guess I'm going to answer my own question. I don't exactly know which dependency caused this particular error, but I had recompiled ffmpeg based on the instructions provided at ariandy1.wordpress.com/2013/02/13/raspberry-pi-rasbian-opencv/ and now I managed to get ROS to compile opencv.
Originally posted by evk02 with karma: 218 on 2014-02-05
