I use Ubuntu 12.04 and ROS Fuerte. I want to install RGBD slam.I try above commends in my ros package path
$svn co http://alufr-ros-pkg.googlecode.com/svn/trunk/rgbdslam_freiburg $rosdep update
but while I type this command > rosdep install rgbdslam_freiburg I got these error
ERROR: Rosdep cannot find all required resources to answer your query Missing resource rgbdslam_freiburg ROS path [0]=/opt/ros/fuerte/share/ros ROS path [1]=/opt/ros/fuerte/share ROS path [2]=/opt/ros/fuerte/stacks
Originally posted by ghazaleh on ROS Answers with karma: 15 on 2014-02-04
Make sure your ros workspace is correctly defined. You should not install the rgbdslam package in opt/ros folder. The instructions on the page are very clear. Make sure your ROS environment and workspace is properly set. See this page on how to set up your ros workspace ROS workspace tutorial
Originally posted by Vegeta with karma: 340 on 2014-02-04
Comment by Wilk on 2014-02-04:
a good idea is if You have created a workspace to add these lines in .basrc file:
  1. source /opt/ros/fuerte/setup.bash
  2. source ~/fuerte_workspace/setup.bash
If You have created Your workspace and it worked and after some time reseted a computer then You "lose" path and You need to add it again (or bash it :) )
