I am using this code
topic is: /camera/depth/image
type: /sensor_msgs/Image
According to the code, (msg->data[0]) is providing the value of Top-Left Corner.
I wanted to ask:
  1. How can I get the value of the Top-Right Corner, Centre, etc.
  2. How can I get the normal depth value that can tell me the distance from the object? Do I need to do some mathematical work or is there a method?
Originally posted by Safeer on ROS Answers with karma: 66 on 2014-02-01
Comment by askkvn on 2021-06-24:
Your reference code helped, thanks
In the code the message is already converted to a cv::Mat ( cv_ptr->image ). Use this Matrix if you want to do some processing of the data.
E.g. you can use
float dist_val = cv_ptr->image.at<float>( 10, 10 );
to get the value at 10, 10. (There are much faster methods if you not just want to access one pixel, though).
See, http://docs.opencv.org for infos on how to handle your data with OpenCV.
Originally posted by Wolf with karma: 7555 on 2014-02-07
Post score: 4
Comment by Safeer on 2014-02-10:
Thanks for your help. I visited the link you gave. Please guide me which topics/tutorials should I follow?
Comment by Wolf on 2014-02-10:
That very much depends on what you actually want to do. Probably some of the core and improc tutorials. If you want to do object detection: "Creating Bounding boxes and circles for contours"(particularly cv::findContours() usage). Threshold works also for dist imgs. Likely you need some normalizing.
Comment by Safeer on 2014-02-17:
Thanks for your reply.
Thanks, @Wolf, this solution worked for me. I have used /camera/depth/image_raw as an input rostopic.
My answer with complete code (c++): https://answers.ros.org/question/141741/calculate-depth-from-point-cloud-xyz/?answer=381085#post-id-381085
Extra:
  • To get image dimension: std::cout << "Image dimension (Row x Col): " << cv_ptr->image.rows << " x " << cv_ptr->image.cols << endl;
  • To get image global max and min depth values:
double max = 0.0;
cv::minMaxLoc(cv_ptr->image, &min, &max, 0, 0);
std::cout << "Min value: " << min << " " << "Max value: " << max << endl;```
