Hello, we are using the Velodyne HDL-64E S2 with ROS Hydro for indoor mapping. During this we saw, that the ROS.driver for the Velodyne creates Pointclouds where the Laser-beams are in an ellipse instead of a cicle.
In the following archive are 3 Scans taken at the same possition: archive
  • "shelf.pcap": recorded with the original DSR-driver (Version 2.0.0)
  • "2014-01-30-12-49-45_0.bag": recorded with the ROS-driver
  • "2014-01-30-15-17-49_0.bag": recorded with the PCL-HDL-grabber (the pointcloud is turned by 90° for some reason)
There you can see the same room (and out of the window). Where the scans taken with the original- and pcl-driver are showing straight walls, the ros-driver does not.
The following archive shows the same drivers at a different possition, where the laser-beams hitting mostly the ground: archive
  • "floor.pcap": recorded with the original DSR-driver (Version 2.0.0)
  • "2014-01-30-16-49-10_0.bag": recorded with the ROS-driver
  • "2014-01-30-16-50-23_0.bag": recorded with the PCL-HDL-grabber
There you can see that the original- and pcl-driver are displaying one beam as a circle, where the ros-driver is creating an ellipse.
This is the launch-file that was used for the ros-driver: file
Does anybody has the same experience and/or a solution, or do we have an error in our launch-file?
Originally posted by Tobias Neumann on ROS Answers with karma: 179 on 2014-01-30
Comment by joq on 2014-01-30:
I am away this week, and cannot see your examples. An ellipse is normal if the device is not exactly perpendicular to the floor.
Comment by Tobias Neumann on 2014-01-30:
Thank you for your fast reply. That is correct, but just the ros-driver is showing this. With the ros-driver also the walls are not straight and the velodyne might not be 100% perpendicular to the floor, but not as far as you would see this results.
I took two screenshots for you. I didn't touch the robot/velodyne during the scans. They were taken right after each other at the exact same position. If you save both pictures and switch between them, you can see the difference.
Comment by joq on 2014-02-03:
What calibration file are you using?
Comment by Tobias Neumann on 2014-02-04:
For the DSR- and PCL-driver we are using this config file: http://robotics.fh-aachen.de/pictures/db.xml For the ROS-driver we are using this: http://robotics.fh-aachen.de/pictures/HDL62S2db.yaml
But the config file saves a config for a laser-beam. If there would be an error, each laser-beam still would create one cycle on a ground. Or am I wrong here?
Comment by joq on 2014-02-04:
I agree that configuration is unlikely to cause this error. But, I would prefer to eliminate as many differences as possible. Would you mind running gencalibration.py on your db.xml to take that out of the comparison? See http://wiki.ros.org/velodyne_pointcloud?distro=hydro#gen_calibration.py docs.
Comment by Tobias Neumann on 2014-02-12:
Sorry for my late reply. I run the calibration on the db.xml. The result you can find here: http://robotics.fh-aachen.de/pictures/db.yaml (it seems to be similar to the HDL62S2db.yaml-file I uploaded in the last post).
I have not observed this type of distortion with our hardware. It looks like a bug, maybe something different about the 64E S2. Exactly which version of the PCL driver are you using for comparison?
Please open a new issue, and I will try to figure out what is going wrong. There are a couple of other issues with that driver that need work, so it's time to give it more attention.
Don't bother repeating the information here, we'll just link back to this question.
Originally posted by joq with karma: 25443 on 2014-02-12
Comment by Tobias Neumann on 2014-02-14:
I opend an issue ( https://github.com/ros-drivers/velodyne/issues/21 ). I used the pcl from the ubuntu 12.04/ros-hydro repositorys. It seems like Version 1.7.0 (in folder /usr/lib, do you know a different way to get the version number?)
Comment by joq on 2014-02-14:
I should be able to figure out what driver is included in PCL 1.7. I presume you have libpcl-1.7-all-dev and not the old ros-hydro-pcl package.
I have installed ros-hydro-pcl-ros what depends libpcl-1.7-all, what depends libpcl-1.7-all-dev. And I don't have the ros-hydro-pcl package. With apt-cache show libpcl-1.7-all-dev it shows Version 1.7.0-2 I hope that answers your question.
Yes, thanks.
