I've built OpenCV 2.4.7 with CUDA support and tried to link it to my package. When I run my node, I get this error error.
OpenCV Error: No GPU support (The library is compiled without CUDA support) in mallocPitch, file /tmp/buildd/ros-groovy-opencv2-2.4.6-1precise-20131020-2316/modules/core/src/gpumat.cpp, line 879 terminate called after throwing an instance of 'cv::Exception' what():  /tmp/buildd/ros-groovy-opencv2-2.4.6-1precise-20131020-2316/modules/core/src/gpumat.cpp:879: error: (-216) The library is compiled without CUDA support in function mallocPitch
When I compile, I get the following errors:
runtime library [libopencv_videostab.so.2.4] in /usr/local/lib may be hidden by files in:
  /opt/ros/groovy/lib
runtime library [libopencv_video.so.2.4] in /usr/local/lib may be hidden by files in:
  /opt/ros/groovy/lib
runtime library [libopencv_superres.so.2.4] in /usr/local/lib may be hidden by files in:
  /opt/ros/groovy/lib
runtime library [libopencv_stitching.so.2.4] in /usr/local/lib may be hidden by files in:
  /opt/ros/groovy/lib
runtime library [libopencv_photo.so.2.4] in /usr/local/lib may be hidden by files in:
  /opt/ros/groovy/lib
runtime library [libopencv_objdetect.so.2.4] in /usr/local/lib may be hidden by files in:
  /opt/ros/groovy/lib
runtime library [libopencv_nonfree.so.2.4] in /usr/local/lib may be hidden by files in:
  /opt/ros/groovy/lib
runtime library [libopencv_ml.so.2.4] in /usr/local/lib may be hidden by files in:
  /opt/ros/groovy/lib
runtime library [libopencv_legacy.so.2.4] in /usr/local/lib may be hidden by files in:
  /opt/ros/groovy/lib
runtime library [libopencv_imgproc.so.2.4] in /usr/local/lib may be hidden by files in:
  /opt/ros/groovy/lib
runtime library [libopencv_highgui.so.2.4] in /usr/local/lib may be hidden by files in:
  /opt/ros/groovy/lib
runtime library [libopencv_gpu.so.2.4] in /usr/local/lib may be hidden by files in:
  /opt/ros/groovy/lib
runtime library [libopencv_flann.so.2.4] in /usr/local/lib may be hidden by files in:
  /opt/ros/groovy/lib
runtime library [libopencv_features2d.so.2.4] in /usr/local/lib may be hidden by files in:
  /opt/ros/groovy/lib
runtime library [libopencv_core.so.2.4] in /usr/local/lib may be hidden by files in:
  /opt/ros/groovy/lib
runtime library [libopencv_contrib.so.2.4] in /usr/local/lib may be hidden by files in:
  /opt/ros/groovy/lib
runtime library [libopencv_calib3d.so.2.4] in /usr/local/lib may be hidden by files in:
  /opt/ros/groovy/lib
My CMakeLists.txt file is as follows:
project(objectdetect)
## Find catkin macros and libraries
## if COMPONENTS list like find_package(catkin REQUIRED COMPONENTS xyz)
## is used, also find other catkin packages
    COMPONENTS
    roscpp
    message_generation
    cv_bridge
    sensor_msgs
    std_msgs
#Find opencv packages
find_package(OpenCV 2.4.7 REQUIRED)
#Find the CUDA packages
find_package(CUDA REQUIRED)
#Fix for error messages()
set(config )
catkin_package(
   CATKIN_DEPENDS roscpp
   cv_bridge
include_directories(${OpenCV_INCLUDE_DIRS})
cuda_add_library(objectdetect.a objectdetect.cu rslvr.cu OPTIONS -G)
cuda_add_cufft_to_target(objectdetect.a)
add_executable(objectdetect_node objectdetect_node.cpp)
target_link_libraries(objectdetect_node
    objectdetect.a
    ${catkin_LIBRARIES}
    ${OpenCV_LIBS}
Can anybody explain why this is linking to the ROS OpenCV package and not my /usr/local version? Also, how do I fix it?
Originally posted by DiJuMx on ROS Answers with karma: 1 on 2014-01-27
You have a problem similar to this one: http://answers.ros.org/question/32284/cmakelist-find_package-opencv-svn or even this one http://answers.ros.org/question/47249/problem-with-using-opencv_gpu-inside-ros
Try to export OpenCV_DIR to your local installation of OpenCV. More details are available in the answer to the first similar question and in the documentation of find_package.
Having both OpenCV versions installed can lead to clashes between libraries. You can try to update your LD_LIBRARY_PATH/PKG_CONFIG_PATH (if the scripts rely on pkg-config) accordingly, i.e. something like:
export LD_LIBRARY_PATH=/usr/local/lib:$LD_LIBRARY_PATH
export PKG_CONFIG_PATH=/usr/local/lib/pkgconfig:$PKG_CONFIG_PATH
You may also need to set CMAKE_LIBRARY_PATH="/usr/local/lib" for CMake.
If you just need OpenCV with CUDA support for ROS, you can recompile the package with CUDA support activated.
Originally posted by bchr with karma: 596 on 2014-01-27
Comment by DiJuMx on 2014-01-27:
Unfortunately exporting CMAKE_PREFIX_PATH and OpenCV_DIR seems to fix the compile errors but not the runtime errors. It's still looking for groovy libs.
Comment by bchr on 2014-01-27:
For the runtime error, add the directory to LD_LIBRARY_PATH before the ROS directory. It basically stops at the first correct library it finds (in your case, the one in /opt/ros/groovy/lib must appear first in LD_LIBRARY_PATH).
I have /usr/local/lib first in LD_LIBRARY_PATH and it's still giving me runtime errors.
Is the only reason for you to use this second OpenCV the CUDA support? It may be smarter to just use the ROS one that you recompile with CUDA support (-DWITH_CUDA=ON).
That's right. However, I consider rebuilding ROS a last resort as I'm on a University Computer. I'm more concerned with why catkin is linking to ROS libraries rather than the libraries specified.
Can you try with: export CMAKE_PREFIX_PATH=/usr/local:$CMAKE_PREFIX_PATH ? (cf. second answer I linked)
It's already in my .bashrc ... do you want it before or after the Lines where I source my setup.bash files?
The problem with catkin/CMake is that it tends to hide errors when trying to link with other libraries. I had a lot of problems when linking with Ogre 1.8 on a system with Ogre 1.9 installed. CMAKE_LIBRARY_PATH + PKG_CONFIG_PATH + LD_LIBRARY_PATH seemed to do the trick for all possible scenarios.
The linking errors have returned again. I think it's because I removed my build directory. It's also happening with another package in the same workspace, which does need opencv but not the CUDA enabled version...
