Hi, I am trying to use the global planner global_planner.
It finds a path either in dijsktra or A* and changing the different parameters as this image shows
sweet global path
But then the robot stays still and (most of the times) I get this warning:
[ WARN] [1390404456.350870633, 3038.563000000]: Invalid Trajectory 0.000000, 0.000000, -0.300000, cost: -1.000000
until a fatal error appears, after 6 seconds:
[ERROR] [1390404456.403586383, 3038.611000000]: Aborting because a valid control could not be found. Even after executing all recovery behaviors
  • Is there some parameter or remap missing in the global_planner wiki?
  • Is there any example of the global_planner with a launch and yaml files?
Thanks in advance!
Update
I found out that the global_plan publishes the poses from goal to origin whereas navfn publishes them from origin to goal. I would say this is the problem that makes the robot stay still, I copy a couple of results:
oringin (x≅0) and goal (x≅1) of a path in navfn:
  pose:
    position:
      x: -0.1
      y: -0.05
  pose:
    position:
      x: 0.998614728451
      y: 0.0215734690428
oringin (x≅0) and goal (x≅1) of a path in global_planner:
  pose:
    position:
      x: 1.0
      y: 0.0
  pose:
    position:
      x: -0.25
      y: -0.05
Originally posted by martimorta on ROS Answers with karma: 843 on 2014-01-22
I'm pushing a patch but I've just made it work reversing the vector of the plan.
https://github.com/ros-planning/navigation/blob/hydro-devel/global_planner/src/planner_core.cpp#L329
Originally posted by martimorta with karma: 843 on 2014-01-23
