Hi,
Could use some help on this one.
This one works on my robot (I copy the map files manually to the /tmp directory before roslaunching it):
 <launch>
      <!--- Run the kinect -->
      <include file="$(find turtlebot_bringup)/kinect.launch" />
      <!-- Run the map server -->
      <node name="map_server" pkg="map_server" type="map_server" args="/tmp/my_map_waalre.yaml" />
      <!--- Run AMCL -->
      <include file="$(find turtlebot_navigation)/config/amcl_turtlebot.launch" />
      <!--- Run Move Base -->
      <include file="$(find turtlebot_navigation)/config/move_base_turtlebot.launch" />
    </launch>
But this one not and comes with error
<launch>
  <node name="map_server" pkg="map_server" type="map_server" args="/home/turtelbot/fuerte_workspace/sandbox/robo/my_map_waalre.yaml" />
  <!--- Run AMCL -->
</launch>
So same file but just in a different directory. I must be overseeing something simple. error it produces:
process[map_server-8]: started with pid [20619] [ERROR] [1389437922.013953806]: Map_server could not open /home/turtelbot/fuerte_workspace/sandbox/robo/my_map_waalre.yaml. process[amcl-9]: started with pid [20630] process[move_base-10]: started with pid [20679] [map_server-8] process has died [pid 20619, exit code 255, cmd /opt/ros/fuerte/stacks/navigation/map_server/bin/map_server /home/turtelbot/fuerte_workspace/sandbox/robo/my_map_waalre.yaml __name:=map_server __log:=/home/turtelbot/.ros/log/531236a0-7aaf-11e3-8077-94dbc9f717d5/map_server-8.log]. log file: /home/turtelbot/.ros/log/531236a0-7aaf-11e3-8077-94dbc9f717d5/map_server-8*.log
Any clues?
Thanks
Originally posted by Charel on ROS Answers with karma: 81 on 2014-01-11
by writing down the question it triggers the mind. Opened the .yaml file and there was a reference of the .pgm file in the /tmp directory. Updated it and now it works.
Originally posted by Charel with karma: 81 on 2014-01-11
Post score: 4
Comment by bahaa on 2014-08-25:
i faced the same problem, but i didn't fund in the yaml file any reference to the .pgm file!
Comment by tanghz on 2015-03-04:
yes, it has a reference to the .pgm file in the yaml file. Open the yaml file, and you could find these word in the first line::image: /home/...../name.pgm
Comment by Elise on 2015-08-19:
How exactly did you update it?
Comment by Charel on 2015-08-20:
indeed, open .yaml file with text editor like gedit, in the first line you will find the path name.
