update: assuming there are no USB 2.0 to 3.0 adapters since 3.0 was to be compatabile does ubuntu 13.10 updated kernel off any hope. I am running 13.04
update: tried to reinstall everything then run freenect launch. I get the following first waiting message then I plug the device in and get what follows. The USB ports are 3.0
[ INFO] [1390668700.050552116]: No devices connected.... waiting for devices to be connected
[ INFO] [1390668703.054328712]: Number devices connected: 1
[ INFO] [1390668703.054588759]: 1. device on bus 000:00 is a Xbox NUI Camera (2ae) from Microsoft (45e) with serial id '0000000000000000'
[ INFO] [1390668703.056447295]: Searching for device with index = 1
[ INFO] [1390668703.095462065]: No matching device found.... waiting for devices. Reason: [ERROR] Unable to open specified kinect
Update: There seems to be some dissusion on a share lib causing some issues: I looked for it on my machine and it looks a bit confused any thought this.
sudo glview
glview: error while loading shared libraries: libfreenect.so.0.2: cannot open shared object file: No such file or directory
viki@viki:~$ glview
Kinect camera test
Number of devices found: 1
Could not open device
sudo find / -name libfreenect.so -ls
15341498    0 lrwxrwxrwx   1 viki     viki           18 Jan 11 13:08 /home/viki/catkin_ws/src/KinectLibs/libfreenect/build/lib/fakenect/libfreenect.so -> libfreenect.so.0.2
12716955    0 lrwxrwxrwx   1 viki     viki           18 Jan 11 13:08 /home/viki/catkin_ws/src/KinectLibs/libfreenect/build/lib/libfreenect.so -> libfreenect.so.0.2
11141534    0 lrwxrwxrwx   1 root     root           18 Oct  9 21:08 /opt/ros/hydro/lib/fakenect/libfreenect.so -> libfreenect.so.0.1
10883699    0 lrwxrwxrwx   1 root     root           18 Oct  9 21:08 /opt/ros/hydro/lib/libfreenect.so -> libfreenect.so.0.1
9438521    0 lrwxrwxrwx   1 root     root           18 May 25  2012 /usr/lib/x86_64-linux-gnu/fakenect/libfreenect.so -> libfreenect.so.0.1
7355096    0 lrwxrwxrwx   1 root     root           18 May 25  2012 /usr/lib/x86_64-linux-gnu/libfreenect.so -> libfreenect.so.0.1
7480477    0 lrwxrwxrwx   1 root     root           18 Jan 11 13:08 /usr/local/lib64/fakenect/libfreenect.so -> libfreenect.so.0.2
7357524    0 lrwxrwxrwx   1 root     root           18 Jan 11 13:08 /usr/local/lib64/libfreenect.so -> libfreenect.so.0.2
viki@viki:~$
Update: There is a CD with my kinetic. Is there anything useful in this to address this issue?
Update: If I unplug the device and run glview again I get: From what I can see this is a known problem with the linux kernel since 2012 but little has been done to address it. I tried several solutions in the blogs but non seem to work
Kinect camera test
Number of devices found: 0
Update: I tried the following utility
freenect-glview
Kinect camera test
Update: lsusb -v
Bus 003 Device 021: ID 045e:02ae Microsoft Corp. Xbox NUI Camera
Device Descriptor:
  bLength                18
  bDescriptorType         1
  bcdUSB               2.00
  bDeviceClass            0 (Defined at Interface level)
  bDeviceSubClass         0
  bDeviceProtocol         0
  bMaxPacketSize0        64
  idVendor           0x045e Microsoft Corp.
  idProduct          0x02ae Xbox NUI Camera
  bcdDevice            2.05
  iManufacturer           2 Microsoft
  iProduct                1 Xbox NUI Camera
  iSerial                 3 0000000000000000
  bNumConfigurations      1
  Configuration Descriptor:
    bLength                 9
    bDescriptorType         2
    wTotalLength           32
    bNumInterfaces          1
    bConfigurationValue     1
    iConfiguration          0
    bmAttributes         0xc0
      Self Powered
    MaxPower               16mA
    Interface Descriptor:
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        0
      bAlternateSetting       0
      bNumEndpoints           2
      bInterfaceClass       255 Vendor Specific Class
      bInterfaceSubClass      0
      bInterfaceProtocol    255
      iInterface              0
      Endpoint Descriptor:
        bLength                 7
        bDescriptorType         5
        bEndpointAddress     0x81  EP 1 IN
        bmAttributes            1
          Transfer Type            Isochronous
          Synch Type               None
          Usage Type               Data
        wMaxPacketSize     0x0bc0  2x 960 bytes
        bInterval               1
        bLength                 7
        bDescriptorType         5
        bEndpointAddress     0x82  EP 2 IN
        bmAttributes            1
          Synch Type               None
          Usage Type               Data
        bInterval               1
Device Qualifier (for other device speed):
  bLength                10
  bDescriptorType         6
  bcdUSB               2.00
  bDeviceSubClass         0
  bDeviceProtocol         0
  bMaxPacketSize0        64
Device Status:     0x0001
  Self Powered
Update: Is there anyway to further debug this problem of openni not recognizing my device plugged in via the USB port. Or is there some kind of work around?
Update: as requested.
(http://answers.ros.org/upfiles/13892061651366488.png)
viki@viki:~$ roswtf
Loaded plugin tf.tfwtf
No package or stack in context
Static checks summary:
Found 2 warning(s).
Warnings are things that may be just fine, but are sometimes at fault
WARNING You are missing core ROS Python modules: rosrelease --
WARNING You are missing Debian packages for core ROS Python modules: rosrelease (python-rosrelease) --
Found 2 error(s).
ERROR Not all paths in ROS_PACKAGE_PATH [/home/viki/catkin_ws/src:/opt/ros/hydro/share:/opt/ros/hydro/stacks] point to an existing directory:
 * /opt/ros/hydro/stacks
ERROR Not all paths in PYTHONPATH [/home/viki/catkin_ws/devel/lib/python2.7/dist-packages:/opt/ros/hydro/lib/python2.7/dist-packages] point to a directory:
 * /home/viki/catkin_ws/devel/lib/python2.7/dist-packages
Beginning tests of your ROS graph. These may take awhile...
analyzing graph...
... done analyzing graph
running graph rules...
... done running graph rules
running tf checks, this will take a second...
... tf checks complete
Online checks summary:
No errors or warnings
Update tried recommendation in comment. I even tried putting in leading zeros nothing seems to work.
roslaunch openni_launch openni.launch device_id:=3@0
Still getting device not connected.
[ INFO] [1389205418.542387296]: No devices connected.... waiting for devices to be connected
Update: I tried putting in 3@4 for the device number but it says then it can not find device 3@4.
[ INFO] [1389131675.359641075]: No matching device found.... waiting for devices. Reason: std::string openni2_wrapper::OpenNI2Driver::resolveDeviceURI(const string&) @ /tmp/buildd/ros-hydro-openni2-camera-0.1.1-0raring-20131113-2050/src/openni2_driver.cpp @ 623 : Invalid device number 1, there are 0 devices connected
I was using my kinetic camera and it worked fine with rviz. But a few months later not sure what changed openni_launch says (no device detected) If I run openni2_launch it says (Invalid device number, 0 devices connected. When I run lsusb I get the following output: Any thoughts on how to proceed. Not sure what has changed since I am using the same launch file as installed.
Bus 001 Device 002: ID 8087:0024 Intel Corp. Integrated Rate Matching Hub
Bus 002 Device 002: ID 8087:0024 Intel Corp. Integrated Rate Matching Hub
Bus 003 Device 002: ID 045e:02c2 Microsoft Corp.
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 004 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 001 Device 003: ID 05ac:8509 Apple, Inc. FaceTime HD Camera
Bus 002 Device 003: ID 0424:2513 Standard Microsystems Corp.
Bus 003 Device 003: ID 045e:02ad Microsoft Corp. Xbox NUI Audio
Bus 003 Device 004: ID 045e:02ae Microsoft Corp. Xbox NUI Camera
Bus 002 Device 009: ID 05ac:821d Apple, Inc.
Bus 002 Device 004: ID 0a5c:4500 Broadcom Corp. BCM2046B1 USB 2.0 Hub (part of BCM2046 Bluetooth)
Bus 002 Device 005: ID 05ac:8242 Apple, Inc. IR Receiver [built-in]
Bus 002 Device 006: ID 05ac:0252 Apple, Inc. Internal Keyboard/Trackpad (ANSI)
Originally posted by rnunziata on ROS Answers with karma: 713 on 2014-01-07
It sounds like you have USB 3.0 problems, since you can't use the Kinect on a USB 3.0 port (in general, sometimes it just works, sometimes it doesn't). Is it possible to disable USB 3.0 in your BIOS on a Mac? If not, try changing UsbInterface in /etc/openni/GlobalDefaults.ini to some other value (just try the four other options).
Originally posted by Tim Sweet with karma: 267 on 2014-01-25
Comment by Athoesen on 2014-01-25:
Oh wow, I didn't even see that the first time. But he said that it had worked before I think.
Anyways, yes. 3.0 = no bueno.
Comment by Tim Sweet on 2014-01-25:
Yeah I don't know why it would suddenly stop working...that happened to me once, I never found out the root problem, but it was fixed by changing the UsbInterface field. Maybe some kind of Kernal update?
Comment by rnunziata on 2014-01-25:
The USB line from my Mac GlobalDefaults.ini ; USB interface to be used. 0 - FW Default, 1 - ISO endpoints, 2 - BULK endpoints. Default: Arm - 2, other platforms - 1
Any one look better then the others?
A USB 3.0 to 2.0 adapter won't work, I've tried that with a USB 2.0 hub. I suggest just trying each one of those interfaces, the GlobalDefaults file is loaded when OpenNI is run (ie with roslaunch openni_launch or your own variant) so just modify the file, try to start it, repeat.
Your update with the most recent output tells me the interface (from GlobalDefaults.ini) might be the problem: it seems able to identify the camera on the bus, but won't get its serial number so it can't talk to the camera.
Can you disable USB 3.0 in OpenFirmware (see: http://goo.gl/XJpAvQ)?
Comment by rnunziata on 2014-01-26:
Thanks Tim. I have been scanning for any info on how to turn off/on usb in the BIOS. Not something I normally do and would be great to see instructions or a demo. But I can not seem to find anything. Any idea where I can look?
Comment by Tim Sweet on 2014-01-26:
I've never owned a Mac so I have no clue..I only use one for video editing :) I'll ask around in my lab and see if anyone knows. It might not be possible. Did the UsbInterface thing not work?
I came across this which is encouraging but does not tell me how to do this on a mac. http://rog.asus.com/forum/showthread.php?37159-How-do-I-disable-or-delete-the-USB-3.0-drivers. Thank you .
