I have a rospy node that has both a main loop and a subscriber callback that both need to modify the same global variable and I'm wondering if I have to use thread locking to prevent weirdness. The following snippet exhibits what I mean. Does the variable self.move_cmd.angular.z need locking in this situation?
def __init__():
    rospy.init_node("test")
    rospy.subscriber('roi', RegionOfInterest, self.roi_callback)
        if not target_visible:
            self.move_cmd.angular.z = 0
        rospy.sleep(1)
def roi_callback(self, msg):
    if msg.width !=0 and msg.height != 0:
       self.move_cmd.angular.z = 0.1 * msg.x_offset
Thanks!
patrick
Originally posted by Pi Robot on ROS Answers with karma: 4046 on 2014-01-06
Since callbacks in rospy are processed in a separate thread, I'm pretty sure you need locking for a case like this.
Originally posted by ahendrix with karma: 47576 on 2014-01-07
Comment by Pi Robot on 2014-01-07:
Thanks Austin. I'll lock it up.
