I'm working on a kinect project. I'm trying to write a pair of files that test out the PointCloud2 sensor message. I don't know how to make the 'listener' python script read the value that I have created in the 'talktest' script. I am using the class defined here:
sensor_msgs/point_cloud2.py (I could not post a link)
This is my code. These are my includes. I use them pretty much the same in both files.
#!/usr/bin/env python
import rospy
import sensor_msgs.point_cloud2 as pc2
from sensor_msgs.msg import PointCloud2, PointField
This is the 'talktest' code.
#talktest
def test():
    rospy.init_node('talktest', anonymous=True)
    pub_cloud = rospy.Publisher("camera/depth_registered/points", PointCloud2)
        pcloud = PointCloud2()
        # make point cloud
        cloud = [[33,22,11],[55,33,22],[33,22,11]]
        pcloud = pc2.create_cloud_xyz32(pcloud.header, cloud)
        pub_cloud.publish(pcloud)
        rospy.loginfo(pcloud)
        rospy.sleep(1.0)
if __name__ == '__main__':
    try:
        test()
    except rospy.ROSInterruptException:
        pass
Then I have written a script that listens for point cloud data. It always throws a AttributeError.
#listener
def listen():
    rospy.init_node('listen', anonymous=True)
    rospy.Subscriber("camera/depth_registered/points", PointCloud2, callback_kinect)
def callback_kinect(data) :
    # pick a height
    height =  int (data.height / 2)
    # pick x coords near front and center
    middle_x = int (data.width / 2)
    # examine point
    middle = read_depth (middle_x, height, data)
    # do stuff with middle
def read_depth(width, height, data) :
    # read function
    if (height >= data.height) or (width >= data.width) :
        return -1
    data_out = pc2.read_points(data, field_names=None, skip_nans=False, uvs=[width, height])
    int_data = next(data_out)
    rospy.loginfo("int_data " + str(int_data))
    return int_data
    try:
        listen()
        pass
I always get this error:
[ERROR] [WallTime: 1389040976.560028] bad callback: <function callback_kinect at 0x2a51b18> Traceback (most recent call last):
File "/opt/ros/hydro/lib/python2.7/dist-packages/rospy/topics.py", line 681, in _invoke_callback cb(msg) File "./turtlebot_listen.py", line 98, in callback_kinect left = read_depth (left_x, height, data) File "./turtlebot_listen.py", line 126, in read_depth int_data = next(data_out) File "/opt/ros/hydro/lib/python2.7/dist-packages/sensor_msgs/point_cloud2.py", line 74, in read_points assert isinstance(cloud, roslib.message.Message) and cloud._type == 'sensor_msgs/PointCloud2', 'cloud is not a sensor_msgs.msg.PointCloud2' AttributeError: 'module' object has no attribute 'message'
Can anyone tell me how to use this library correctly?
Originally posted by david.c.liebman on ROS Answers with karma: 125 on 2014-01-06
Try adding the following import statement after the 'import rospy' line:
 from roslib import message
--patrick
Originally posted by Pi Robot with karma: 4046 on 2014-01-06
Comment by david.c.liebman on 2014-01-07:
this worked. Thanks. Also, I had to change the read_points() line like this: data_out = pc2.read_points(data, field_names=None, skip_nans=False, uvs=[[width, height]]) note the double square braces around width and height!! Thanks again.
Comment by Pi Robot on 2014-01-07:
Excellent! I haven't used the uvs argument (yet) so that is good to know for the future.
Comment by sabruri1 on 2017-07-26:
Hello! Thank's for your help. I have a question. When I try to test your code, into read_depth method, variable "int_data" has three field. What are they?
Comment by Badal on 2021-09-29:
They are Pointcloud XYZ data for the center (u,v ) pixel correspondence.
