running a fresh install of hydro on a fresh install of ubuntu Precise. According to the tutorial at http://wiki.ros.org/rosserial_arduino/Tutorials/Arduino%20IDE%20Setup
under 3.3 Install ros_lib into the Arduino Environment
"The preceding installation steps created ros_lib, which must be copied into the Arduino build environment to enable Arduino programs to interact with ROS."
ros_lib was not created. any ideas? I rechecked everything in the install, all is well, no error messages etc.
Also, it says to put ros_lib in the libraries folder of the sketchbook. My libraries are at /usr/share/arduino/libraries
Does it matter?
regards, Richard
Originally posted by richkappler on ROS Answers with karma: 106 on 2013-12-14
The ros_lib should be installed in your Arduino "sketchbook/libraries". To install the ros_lib in the sketchbook use rosrun rosserial_arduino make_libraries.py <sketchbook>/libraries/ . You will have to make the libraries folder and the sketchbook should automatically be generated in the home directory after the Arduino IDE is opened once.
Originally posted by tonybaltovski with karma: 2549 on 2013-12-15
Post score: 4
Comment by uzair on 2014-02-27:
it should be rosrun and not ros
Comment by tonybaltovski on 2014-02-28:
Sorry, you are correct.
