I'm looking for an inexpensive DC brushed motor controller board with serial interface (preferably USB), encoder feedback, at least 12V/3A continuous current and ROS driver. The only direct reference I found is ROS Motor Controller Drivers at ROS Wiki, but it lists only 3 options and Roboteq AX2550 sort of qualifies, except of the cost. Are there any other options?
Originally posted by Paul Jurczak on ROS Answers with karma: 31 on 2013-12-11
Comment by dornhege on 2013-12-11:
My advise would be to widen your options and drop the ROS support requirement. Developing a ROS driver for a serial interface for a motor controller board should be fairly easy.
What voltage?
I think that your best option is to get yourself and Arduino and some sort of motor control shield. It is trivial to write a program for it take commands and publish sensor data via the serial port.
You would then have to write a small ROS node that sends commands to the arduino and publishes the encoder data back to ROS.
Originally posted by Dereck with karma: 1070 on 2013-12-11
Comment by Paul Jurczak on 2013-12-11:
12V or more. I'm considering using microcontroller board with motor driver and writing my own ROS driver - just wanted to know what are the options.
Comment by tonybaltovski on 2013-12-11:
I agree with Dereck and I am using that for two 12V motors at 6 A max.
Comment by bit-pirate on 2014-01-21:
If you use an Arduino, then you can make use of rosserial (http://wiki.ros.org/rosserial), which already provides everything you need to publish and receive ROS messages.
The Roboclaw has a lot of features and good reviews. I hear you should buy directly from the manufacturer since earlier firmwares are buggy.
I would suggest just buying one of these and writing a rospy pyserial node to communicate to the controller:
http://www.orionrobotics.com/Motor-Controllers_c_125.html
Comment by sonyccd on 2016-03-21:
I have written a driver for this board
link text
